frame flex death wobble - Ford Truck Enthusiasts Forums
Old 11-05-2011, 07:01 PM
mike83f250's Avatar
mike83f250 mike83f250 is offline
mike83f250 is starting off with a positive reputation.
i have a 82 f250 with dana 60 axle.the truck also has 8in lift,3 in body. when i trun the wheel, back and forth, you can see the front fram flex a lot.is there any way to take some , of the flex out.
Old 11-05-2011, 07:20 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Is your bumper on the truck?
Old 11-05-2011, 08:34 PM
mike83f250's Avatar
i have the bumper on it
Old 11-05-2011, 10:22 PM
MarksA-C's Avatar
MarksA-C MarksA-C is offline
MarksA-C is starting off with a positive reputation.
Have someone turn the wheel while you are under the truck, look near the steering gearbox area on the frame when its turning. Keep a close eye for any broken are cracked areas. With the truck being lifted there is a LOT of extra force on that section.
My 92 had the cross member break off right by the gearbox. $400 later it was all reinforced and welded together.
You also have death wobble in the title? That might clue more to the frame being damaged and the steering being effected. OR you need new linkages.
Old 11-06-2011, 06:19 AM
Quote:
And the bolts are tight?
Old 11-06-2011, 06:32 AM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
If the frame is actually flexing, engineer and fabricate a brace that will eliminate the flex. If it is flexing it will eventually crack. Many years ago I had a Dodge chassis under a motorhome that drove poorly due to frame flex in the area of the steering box. I fabricated an angle brace that eliminated the flex and the unit drove much better.
Old 11-06-2011, 08:10 AM
Turx Turx is offline
Turx is starting off with a positive reputation.
Just curious, what size tires are on this? Your going to have a lot more stress and flex with the truck parked vs in motion. Are you thinking the frame flex and death wobble are connected? Death wobble can be caused by the tires being out of balance more often than other issues. The bigger they are, the more this happens, although I've seen stock tires cause the wobble as well. If the tires are correctly balanced, check the front end componets, all of them for any play or wear. With "all" the lift on the truck have the drive line angles been corrected? Pitman arm, etc?
Numberdummy/Jefffafa mrpotatohead 1967 - 1972 F-100 & Larger F-Series Trucks 7 12-02-2016 10:10 AM
Body filler with some flex nonrev321 Paint & Bodywork 9 05-21-2016 03:11 PM
Flex Fuel Repair Costs?? 05F350CC Alternative Fuels, Hybrids & Mileage 1 07-07-2015 01:23 PM
1994 FLEX PLATE Callantom 1987 - 1996 F150 & Larger F-Series Trucks 1 06-14-2011 03:52 PM
Flex Fan 1969FordF250 1967 - 1972 F-100 & Larger F-Series Trucks 13 04-20-2004 07:36 PM
Tags
2001, bauer, bed, death, eddie, expedition, f150, f250, f350, flex, flexes, ford, frame, wobble, wobbly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
