Engine Oil Temp.
I have noticed on my truck that my oil temp seems to be MUCH MUCH cooler than you guys are saying.. usually normal temp on my Livewire it says my EOT is around 85-95 all the time.. I will double check that on the way home tonight.. could this just be a faulty EOT sensor.. truck runs great.. mods are all in my signature..
There seems to be some coding issues in a few tuners. My Mini Maxx would tell me my oil temp was 120 degrees at startup after sitting for 2 days. H&S fixed it as soon as it was known. I usually run 198-209 empty. 215 towing. Coolant is always around 195-200, empty or tow. It is even consistent all year around. 33 ambient temp this morning and with winter front I topped at 206 empty for oil and 199 coolant.
yea.. my truck sat all day today .. ambient temp today outside was 65 degrees.. when i started my truck up about 2 hours ago.. it was reading 50 degrees.. doesn't seem right.. i'll have to email IDP.. i was thinking about testing the EOT sensor with an ohm meter.. but i dont know where the damn sensor is.. lol.. anyone know?? have a pic??
EOT runs at 180 Empty and 210 pulling where the WT runs at 190 empty and pulling 215. Yep, WT is higher than EOT. Now the Transmisson runs 180 empty, pulling will reach 215 on longer pulls. Even when ambient 100+ temps, it will run about 3-7 degrees higher. This is using Scangauge II version 4.06.
well that explains everything then... i was gonna say!! this is a load off my shoulders.. i thought there was an issue here.. anyone know if there is a way to get it reprogrammed or if there is a setting to change it to Fahrenheit??
This is after my 40 min drive home last night.. running IDP xtreme street tune.. just normal driving .. most of it sitting in traffic..
6c85c2c4.jpg?t=1322523393
dredmond
02-26-2011 02:48 PM
