Throttle Body Size/CFM/Supports x Horsepower Chart - Ford Truck Enthusiasts Forums
Old 11-05-2011, 04:53 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
I put together this spreadsheet for everyone's reference comparing square surface area across throttle body bores, cfm airflow capability, and what type of horsepower your particular throttle body should support. These numbers could be used for maf sizing and cfm (not hp for maf as that has alot to do with voltage of the meter as well). Hope all enjoy. Mathematical calculations were made and then I used a base throttle body that had been measured for actual flow and applied to other sizes to get approximate cfm and hp calculations. Chart is sized from smallest square surface area to largest.
Old 11-06-2011, 04:30 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Some good info , i should be good with the BBK 61 mm truck TB....
Old 11-06-2011, 08:00 AM
73FOMO's Avatar
I think i have one small correction. The truck TB's should be twin 50's not 51's. Would only make a small diff. I will try and correct and repost those.
Old 11-07-2011, 03:05 PM
blkfordsedan's Avatar
blkfordsedan blkfordsedan is offline
blkfordsedan is starting off with a positive reputation.
I thought the stock '87+ 5.0L Mustang TB was 60mm. I believe my '86 Lincoln LSC 5.0L H.O. (first year for SEFI) has a 59mm or something weird like that.............but I could be wrong.
Here's a calculator that I have used before...........not as "user friendly" as your chart, but still fun to play with!
http://www.revtronix.com/techinfo/ca...rottlebody.php
Old 11-07-2011, 06:11 PM
73FOMO's Avatar
Throttle Body Sizing Calculator | REVTRONIX
I think you are right...87 to 93 is 60mm, pre 86 is 58mm...and I think some of the non performance applications were as low as 55mm. '93 Cobra was 65 and all SN95's were 60mm. The purpose was really to compare sizes vs. airflow and hp...not so much vehicles. But I will make this correction on applications. I also think 5.8 trucks and Lightnings were twin 50's. I will repost with the changes and add the 58mm.
Old 11-07-2011, 09:36 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
5.8 truck uses the same TB as the 5.0 truck and I'm pretty sure they're 52mm but I'll have to check that. Either way your chart clearly demonstrates how rediculously oversized these things are and also how completely unnecessary an even larger throttlebody is on one of these motors.
The 5.8 Lightning uses a totally different intake.. the GT40.. which has a single TB and I don't know what size the TB is but I'd be surprised if was more than 65mm.
Old 11-08-2011, 10:57 AM
73FOMO's Avatar
According to this document...the 5.8 GT40 is single 65MM TB and 5.8's are the same as truck 5.0, twin 50mm.
Old 11-08-2011, 02:13 PM
73FOMO's Avatar
Here are the latest revisions to applications and additional throttle bodies.
Old 11-10-2011, 10:29 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
While the stock intakes could support theoretical horse power, I would like to see some dyno charts to know the rpm capabilities of the stock intakes.
Old 11-11-2011, 05:43 PM
73FOMO's Avatar
This speaks to throttle bodies and not intakes, but a intake technical comparo would be a great addition to this analysis on throttle bodies. Who wants to take the lead...lol?
best cam for 390 FE???? 1976f150dude 1973 - 1979 F-100 & Larger F-Series Trucks 20 11-19-2014 05:03 AM
Found an Air Filter Thread rockittsled 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-11-2014 10:31 AM
Carburetion - how many CFM are required? 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 4 09-06-2013 08:34 PM
How much CFM does an engine need??? ernesteugene 1999 - 2003 7.3L Power Stroke Diesel 19 04-25-2009 01:18 PM
Help with HP/Torque Calculation Lance Hogan FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 09-08-2007 03:31 PM
Tags
400, 460, 50, 94, body, calculator, cfm, chart, f150, hp, mustang, size, sizing, specs, throttle, throttlebodysizehp, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
