Anyone ever had a bad ignition switch?
I had an issue with my radio cutting out, and it seemed to happen when something shimmied the truck (like a speed bump). It wouldn't have power for a while, then would randomly come back on. I noticed that when the radio was out, so were the windshield wipers, and anything else on the hot-in-ACC circuit. This pointed to the ignititon switch, since I could deduce that the issue was upstream. Once I suspected the ignition switch, I found that shaking the key would bring power back to the accessory loads. Bingo.
What is the specific issue in your case? The best way to test the ignition switch, or any switch, is a continuity check. Or, you can see where power drops off as Marc described above.
You can reuse the key part of it if it turns good. I have bought it all new by buying both parts and putting them together. But no need to if the key part is good.
I just replaced mine a week ago. My truck would start with key cranked then shut off with key back to straight up unless I wiggled key just right after it fired. I had weird smell in cab sometimes too almost like I thought burning antifreeze? It turned out it was the pigtail ignition connection slowly getting hot and melting. Had to find new pigtail harness and wrecker wasn't an option. Guys on here helped me out and I found a part # through Rock Auto. My parts stores couldn't find anything until i retried them with my part # and I tracked one down with a 2 day wait time. The pin/rivets on back of ignition were loose, causing a bad connection and made everything bad.
I'm having trouble with the truck just shutting off while driving only a few hundred feet. Just figured it might be the ignition switch since I've had one do that before (not a ford). $18 for a new one and my old one fell apart upon removal so I thought I had the problem licked.
The swap was easy but within a few hundred feet; same thing, the truck just quits, or almost quits if I'm quick on the gas.
Back to square one. I'll have another thread started for that problem so I'll continue the discussion there. https://www.ford-trucks.com/forums/1...tting-out.html
