Is it safe to run the 4.9 with just the exhaust manifolds? I am trying to determine if my cats are plugged and thought it would be a good idea to just take the pipes loose from the manifolds. Would it cause any damage? Is there a better way to check for clogged cats?
The sensors will be disconnected with the pipe off which will be a problem in itself. Have you pulled the codes? Also, if your truck has 100,000 miles or more on it the Cats are due/overdue for a change anyway.
