tips on changing i c m
Old 11-05-2011, 10:51 AM
joekacker's Avatar
joekacker
joekacker is offline
Im hunting for tips on changing my ignition control module, I lost all spark in an instant. I was looking through the book and its pretty bland on directions and instructions, Ive been driving carb rigs for ever, and everything is simplified, Any tips will help a ton thanks
Old 11-05-2011, 11:49 AM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Just a basic unplug it, unbolt it using a 5.5mm thin walled deep socket (auto zone sells em)...coat the new units back plate with heat transfer paste, reinstall. Keep in mind that your ignition failure could be the distributor or something else. Search PIP, ICM, TFI, for some more info
Old 11-05-2011, 11:51 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
What year/model/engine is your truck? Early models had the ICM on the side of the distributor. Later models moved the ICM to a heat sink on the driver side inner fender near the hood hinge.
Either way you will need a thin wall socket to remove the hold down bolts. IIRC it's a 5.5MM.
Old 11-05-2011, 12:47 PM
joekacker's Avatar
joekacker
when I looked at the disty i didnt notice any plug, strange, Its a 5.0 efi 91 f150 xlt.
Old 11-05-2011, 01:46 PM
rla2005's Avatar
rla2005
From this diagram I would say your ignition module is on the driver side inner fender:
1987-95 EFI trucks.
courtesy of FordFuelInjection.com
Here is a photo of what it looks like mounted in it's heatsink:
Make sure the replacement ICM is gray in color. If you have a black one, take it back it's the wrong one for your truck. As stated in a previous post make sure you use a good amount of heat sink compound on the back when you install it.
Country705
19
02-03-2011 11:36 AM
Brewskiie05
09-20-2010 06:41 PM
datzsun
1978 - 1996 Big Bronco
03-27-2008 01:51 PM
buddywest
06-27-2006 04:14 PM
Mreddd
Electrical Systems/Wiring
09-07-2005 10:20 PM
Quick Reply: tips on changing i c m
