Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 11-04-2011, 08:50 PM
Stonesetter1 Stonesetter1 is offline
Garage is empty, add now
Stonesetter1 is starting off with a positive reputation.
'97 F250 7.5 EMISSIONS PROBLEMS
1997 F250 HD 7.5 LITER WITH CHECK ENGINE LITE ON.
SCAN TOOL READ THESE CODES, PO401,PO171,PO174,PO305,PO232,PO300(SHOWED UP YESTERDAY),P1000. THESE SHOW UP ALMOST EVERYTIME.
P1506,P1127,P1703,P1780, THESE ONLY ONCE ABOUT TWO MONTHS AGO.
I'VE BEEN WORKING ON THIS FOR A LONG TIME TO CORRECT THE MOTOR PERFORMANCE AND STILL GET GOOD MPG.(8-10)
NOW I NEED TO SMOG THIS MONTH AND I COULD USE SOME HELP IN ANY IDEAS WHAT IS WRONG. ALREADY BEEN TO TWO MECHANICS AND PREFER TO DO IT MYSELF ANYHOW, I KNOW MY TRUCK BETTER THAN THEM.
SOME VACUUM LINES BROKE WHEN THE HEADS WHERE DONE AND I THINK THAT IS MOST OF MY PROBLEM, INCORRECT ROUTING?
PLEASE HELP IF YOU CAN, THANKS.
  #2 (permalink)
Old 11-06-2011, 10:02 AM
SteveBricks's Avatar
SteveBricks SteveBricks is offline
FTE Administrator
2006 Ford F-250
My Garage
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
There should be a vacuum line routing diagram under your hood. I'd be certain that all of the lines are properly routed and not leaking before trying to diagnose the codes.
__________________
'06 F250 6.0 / '94 F350 7.5
Regional Chapters Moderator
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #3 (permalink)
Old 11-07-2011, 03:43 PM
I have a mechanic friend helping me and checked the vac lines to diagram, they are correct. We took off the IDLE AIR CONTROL VALVE to check it out since it seems like the choke no longer works, do you know how to test one of these?
Also found that #3 cylinder is weak and #4 not working. Doing compression check next.
Spark is good, Fuel injectors?
Any ideas? Thanks
Tags
1997, 75, 97, crossver, emission, emissions, emmisions, f250, faults, ford, liter, passing, problem, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
