Was running and now its not?
Yes you should hear the high pressure pump and the selected in-tank low pressure boost pump run for one second each time you turn on the key with the engine not cranking.
If not I would look at the wiring under the fuel pump (green) and power relays (brown) on the drivers fender. If the wiring looks good under the relays check the fuse links at the starter solenoid and the Inertia switch. For the Inertia switch try pushing the button down on top of it.
Ok so i hear the buzzing when i turn the key. The wiring is good. Im going to run up to the store to get some starting fluid to see wether it isnt getting fuel or isnt getting spark. If it isnt getting fuel what do i look for next. Im pretty sure it is getting spark because it has new plugs and wires.
Coil comes to mind.. How about distributor cap/rotor? Are all the contacts good inside? Possibly timing is off, maybe you mixed up a wire or two when you replaced the plugs/wires?
A good way to know for sure that your wires are correct, is to pull the #1 spark plug then have someone "bump" the engine (with your finger in the hole) until you feel the compression stroke. Then look at where your rotor is pointing, that is #1.
Check the wires at the coil. mine can slide in the plastic and make for a bad connection. Just a thought.... GL
#28
Search PIP and ICM threads here, you may be a victim of this heat related common problem, with an inconsistent spark issue.
#29
dont bother with autozone ignition parts. go to another parts house and get a motorcraft cap/rotor set.
#30
