transfer case drain plug socket size
Bob knows.
10mm
Here is a link to his write up.
Welcome to guzzle's Transfer Case Fluid Change Web Page
EDIT: since we are on the subject. I used an oil pump to refill the transfer case because it was quite difficult to fill with the bottle. I used a gear oil pump designed for a Mercruiser out drive. You can probably pick these up at your local boat supply store. It worked ok but I had to keep refilling the bottle because the pickup shaft wasn't as long as I'd like.
http://www.ebay.com/itm/Outdrive-Low...s_Gear&vxp=mtr
Next time I do this, I'll probably fashion up something different. My home improvement store has little pressurized jugs in the garden center. The larger ones are designed for insecticide or weed control but they have smaller hand held ones also. I'd probably try using one of the smaller jugs and see how that works. I bet it would work well.
http://www.homedepot.com/buy/outdoor...ayer-7667.html
10mm
Last edited by Shake-N-Bake; 11-04-2011 at 11:12 AM. Reason: updated with pump info
thanks greg! even better than that sprayer would be a suction pump
http://www.princessauto.com/all-seas...-transfer-pump
well just with the one hose to suck it up then push it back
I always loosen the fill plug first anyway just to make sure I can fill the thing back up.
fightlivefree
08-14-2015 03:59 PM
2001expy
1997-2006 Expedition & Navigator
09-12-2005 06:28 PM
