EGR Ported Vacuum Switch Question
I agree with the above, it shouldn't matter but for reference the vacuum diagram for a factory Holley 4180 equipped vehicle will have an "S" for the ported vacuum advance source on the carb and "E" for the EGR port on the carb. (Both ports are essentially "ported" but I hooked a vacuum gauge to the EGR port on a 4180 and it only pulled 5" of vacuum off idle, while the ported source matched full manifold vacuum off idle).
YES, that is exactly what is looks like. And the vacuum lines can go to either port?
The problem is, my replacement carburetor doesn't have a separate "E" port for the EGR like my stock carburetor had. I was going to just tee it in to the "S" port on the carburetor, which is the same port the vacuum advance goes to. Will that be ok?
If it's a Holley or an Edelbrock all the installation manuals are available online at the manufacturers website's.
RE: EGR Ported Vacuum Switch Question
FYI. on the 2-port valves, "S" is signal or spark, "E" is EGR valve. When the valve is closed the "E" port is vented internally so that there is no possibility of having vacuum on the EGR valve. Once the operating temperature is reached, "S" and "E" are connected. If you reverse the ports, you will have a vacuum leak at low temperatures.
jmulvihill
03-11-2009 08:02 AM
