HVAX fan only works on high!
Most resistors are replaced by unplugging the electrical connector, removing the two or three screws that hold it in the blower housing, pulling it out of the housing, throwing the old one in the trash, and reversing those instructions to install the new one. Usually it is a 5 minute or less type job.
95 blower motor
Blower motor is in the engine compartment on the firewall directly forward of the passenger seat. Resistor block is in the lower quadrant of the motor housing on the engine side; can be replaced without removing the blower unit.
Depending on YOUR vehicle, the battery may be forward of the blower; my 95 has the battery on the driver's side.
twowheeled
08-23-2011 10:30 AM
The Welder
07-05-2005 08:56 AM
