6.0 No throttle response to now wont start - Ford Truck Enthusiasts Forums
Old 11-03-2011, 06:57 PM
Bull_8878 Bull_8878 is offline
Bull_8878 is starting off with a positive reputation.
Cool 6.0 No throttle response to now wont start
I have a '03 F350 with the dreaded 6.0, had egr and injectors worked on about 3000 mi. ago then all of a sudden it was like some one threw out a ten ton anchor. I got pulled over and put it in park, truck would idle but no throttle response. when I got some one to tow it home as soon as I put it in neutral the engine died. towed it home and got it strted (kinda) ran at real low idle and rough as hell. changed oil again and all filters including fuel. NO HELP, had someone read codes and said had a bad CMP, changed it, NO HELP. Read the FICM and it was good. changed the ICP and plug, Still NO HELP. So is my HP oil pump bad or just a leak at the STC fitting? Can you just change the STC or do you have to change the whole pump?
Old 11-03-2011, 07:04 PM
NewToDiesels's Avatar
NewToDiesels NewToDiesels is offline
NewToDiesels is gaining momentum as a positive member of FTE.
So you don't have any codes currently?
You need a way to check your HPO pressure and you can do that at the ICP connector if you don't have a ScanGauge or something similar. It's possible that it's a HPO issue, but it would be worth it for you to find a way to monitor your HPO system while cranking.
Lacking a gauge - there is a way to use a volt meter to see what the ICP sensor is putting out.
If it turns out to be your STC fitting - you don't have to replace the entire pump, but you do have to remove it to replace the fitting.
Old 11-03-2011, 07:22 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
your 03 does Not have an STC fitting
03s dont have all those HPO issues usually
03 HPO system is alittle diffrent
It might be a IPR issue since you just had work done
did they do an oil cooler too or anything eles????
Old 11-03-2011, 07:24 PM
Quote:
Thanks Benny. Too many 05's today.
Old 11-03-2011, 07:33 PM
BLADE35's Avatar
your code for CMP was just set from the stall event it wasnt bad
Stick around tons of Great people and info here
and welcome to FTE
pull the IPR and check the screen if its clogged or pushed IN or has a hole in it time for a new one
gauges would be a Big help to rule some things out
Old 11-13-2011, 11:00 PM
Cool
well i changed the ipr, and i will shoot the the first ford engineer i meet. and to no avail still wont start. there was no screen on the ipr i pulled out. where did it go?
Old 11-14-2011, 05:38 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
You might just have air in the high pressure oil. It takes some cranking to get it out.
However, before you just "crank away", I would measure the ICP volts. You need 0.8 volts (sometimes a little less does it) to start. A scangaugeII is about the cheapest scan tool - or you can strip some wires at the ICP sensor and measure the voltage there.
Shop screw-up or HPOP belly up bad timing? LindenBruce 6.0L Power Stroke Diesel 7 02-03-2017 10:50 PM
2005 6.0 F250 SD Powerstroke- won't turn over after STC fitting replaced Christopher Soto 1999 to 2016 Super Duty 6 12-18-2016 06:58 PM
STC and Dummies! Peace2Peep Excursion - King of SUVs 12 01-31-2016 08:58 AM
STC and Dummies! Peace2Peep 6.0L Power Stroke Diesel 32 01-22-2016 06:01 PM
2004 6.0 - No start when warm... barttalk 6.0L Power Stroke Diesel 20 06-04-2010 04:05 PM
Tags
2004, 2005, 60, accelarator, diesel, dont, econoline, f250, f350, ford, issues, responce, response, start, throtle, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
