2006 E 450 6.0 Power Stroke
Hello, This is My First Post. Here Goes I have 3 E 450 Shutttle Bussess with 6.0 Power Stroke, I Have one that will Turn Over But will Not Start I Scanned it on a GlobalII and got a code UP 155 Lost comm. with IPC MODULES. What and Where is it Located and Does this Sound Correct.
Lildaryl
Lildaryl
Hows the batterys and alternator
I read a post from Cheeit that said the PCM will reset itself if voltage drops below 9.5 volts
Also check the FICM voltage needs to be 48 volts per tech folder
and scan for ICP it needs 500psi to start
and better yet go thru this
https://www.ford-trucks.com/forums/8...condition.html
and Welcome to FTE
and Welcome to FTE
