po358 code: Help - Ford Truck Enthusiasts Forums
po358 code: Help
Old 11-03-2011, 05:27 PM
t1darian t1darian is offline
t1darian is starting off with a positive reputation.
po358 code: Help
Truck started jerkin etc @ 35 40 mph, check engine light came on and I pulled the code: po358 ignition coil h. So I replaced coil and plug, no change, still have bad miss. Pulled new plug again and it looked like it was real wet, thought maybe injector might be stuck open or somthing so I replaced injector. Still no change . Any ideas as to what else it might be ? Any help would be appreciated.
2000 Excursion 5.4
173,000
Old 11-03-2011, 11:33 PM
trucktech trucktech is offline
trucktech is starting off with a positive reputation.
I had some what of same problem on my v10 and I replaced plugs and no change so I got all new cops and no change so pulled the plugs back out and one had a small crack in the ceramic and so replaced that plug and problem fixed never would I thought had problem with brand new motor craft plugs
Removing #8 spark plug on 2002 5.4L V8 Gary Hughes Modular V8 (4.6L, 5.4L) 4 12-25-2015 10:45 AM
po354, po355, po356, & po358 robin1t2002 1997 - 2003 F150 6 04-23-2012 10:29 AM
Code po358 ?? T Gould 2004 - 2008 F150 0 05-07-2011 04:25 PM
5.4 misfire help please!!!!!! jimmy3411 Modular V8 (4.6L, 5.4L) 6 01-26-2009 06:30 PM
2003 navigator po320 po355,356,357,358 sharpcar 1997-2006 Expedition & Navigator 8 03-22-2008 09:54 PM
Tags
2000, 2008, 358, 54, 68, code, coil, eec, engine, f150, f350, ford, ignition, po358, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
