Radio cuts Out - Ford Truck Enthusiasts Forums
Radio cuts Out
Old 11-03-2011, 03:24 PM
whiteisright whiteisright is offline
whiteisright is starting off with a positive reputation.
Radio cuts Out
Just installed a new jvc kd-s48 stereo and it cuts out for a half a second every couple seconds. Kind of like a scratched cd but it's with the tuner and mp3. The sound "stumbles" and then it very quickly raises back up. it sort of seems like if I wiggle the wires in the back it'll stop. I will check all connections, I use female and male spade connectors and then shrink wrap over each connection. Any ideas? Could it be a faulty deck?
Old 11-03-2011, 07:18 PM
Ok after more driving I found that the volume gets quieter and it stumbles when I accelerate or rev. If I'm sitting at a stop then it's fine. Is this a ground problem? I have constant 12v yellow wire wrapped around a fuse in the fuse box for the time being, I think this could be the problem?
Old 11-07-2011, 09:23 PM
boulderguy boulderguy is offline
boulderguy is starting off with a positive reputation.
This could be any number of things most likely related to the install wiring. the B+ constant sounds like trouble waiting to happen but shouldn't cause this, it's mostly for memory. The switched 12v+ is the real power.
I suggest getting a dedicated Scosche harness for your vehicle & rewire the deck permanantly to it, then just plugging into the existing harness.
Stuff like this happens all the time with diy installs & usually clears up when the wiring is cleaned up.
Old 11-08-2011, 09:19 AM
I don't think there is an existing plug in the harness for a radio connection. But if there is then it's been cut out for a loooong time.
Old 11-08-2011, 09:20 AM
Oh forgot to mention it's in a 1973 f250
Old 11-08-2011, 11:27 AM
Ooooh...they probably hadn't invented constant 12v+ back then ...
Still, start with a multimeter on your power, constant & ground while the radio is running loud & compare to readings at the battery. This load test will tell you where the voltage difference is.
Basically what's happening is the higher voltage when you rev somehow is offset at the deck. 90% chance it's the power/ground, 10% chance the deck is faulty.
Another issue 99f350sd Aerostar 10 02-21-2017 07:53 AM
Truck Cuts Off Seconds After Driving mikewand 2004 - 2008 F150 6 01-11-2017 11:48 AM
2000 3.0 just started cutting off and back on while driving bigredtruck Ranger & B-Series 19 12-16-2016 04:27 PM
Wiring brakes on second trailer 99150 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 12 05-07-2015 07:04 PM
Driver's side speakers cutting out..... pilot4net Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 10 02-10-2012 08:26 PM
Tags
cuts, cutting, duty, expedition, f250, ford, installing, jvc, kd, kds48, problems, radio, review, s48, satellite, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
