2003 transfer case fit a 2001? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-03-2011, 01:48 AM
bluescrew's Avatar
bluescrew bluescrew is offline
bluescrew is gaining momentum as a positive member of FTE.
hey guys, does anyone know if these are the same ???
Old 11-03-2011, 08:39 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Hey Mike.
As long as they are on the 4r100, they are the same. They also need to be both manual shift cases or both ESOF cases.
Old 11-03-2011, 01:00 PM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
And they also both have to be off of the same type transmission. Manuals and autos have a different number of splines on the inputs.
Old 11-03-2011, 08:14 PM
bluescrew's Avatar
thanks for the replies guys. it was off a 6.0... so 5r100.. it will not fit. thanks guys!
what tpe of transfer case do i have with an auto with esof?
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
case, f350, fit, transfer, yrars
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
