driver side window goes up and down slow
Old 11-02-2011, 10:02 PM
trucktech's Avatar
trucktech
trucktech is offline
my driver window goes up and down really slow and the other moring had to stop and help it all the way up. Is this the window regulator? or motor?
thanks btw it is a 2000 v10 limited 4x4
Old 11-03-2011, 07:21 AM
njneer1's Avatar
njneer1
njneer1 is offline
It may just need the tracks lubed up
Old 11-03-2011, 09:42 AM
jayc3169's Avatar
jayc3169
jayc3169 is offline
That's what she said!
Ok, I'm sorry, I'm done. LOL
Old 11-03-2011, 10:06 AM
tylerhughes's Avatar
tylerhughes
tylerhughes is offline
Same thing happened to my passenger window when I first bought the truck. Sometimes it wouldnt respond to the switch at all.....I just swapped the motor out with the drivers side rear door since the passenger window gets used more. Lubed up all the tracks but that same motor still has problems with going slow/not working sometimes
Old 11-03-2011, 12:10 PM
dosecobanya's Avatar
dosecobanya
dosecobanya is offline
I had the same thing, hit them all with a silicone lube(less mess) and now no problem, but do them all at once. Use the staw, put it in the corner of the track with the window down and spray for about 10 sec. Hope it's that simple for ya.
Old 11-03-2011, 12:33 PM
Skinsfan6's Avatar
Skinsfan6
Skinsfan6 is offline
My driver's side does this also. I changed the motor and it helped none. Returned the motor, lubed the hell out of the felt window tracks with silicone spray. It helped for a day or two until it wore off. I believe the problem lies in the felt having worn off the window tracks on the inside where the edge of the glass rides. I think only a longer lasting lube or new window track will fix it. It really pisses me off.
Daviddc114
07-06-2016 10:56 PM
01X7.3psd
06-20-2011 07:02 PM
PsD007.3
13
12-08-2009 12:07 PM
kilika77
1997 - 2003 F150
11-12-2005 09:21 PM
Quick Reply: driver side window goes up and down slow
