driver side window goes up and down slow - Ford Truck Enthusiasts Forums
Old 11-02-2011, 10:02 PM
trucktech trucktech is offline
trucktech is starting off with a positive reputation.
my driver window goes up and down really slow and the other moring had to stop and help it all the way up. Is this the window regulator? or motor?
thanks btw it is a 2000 v10 limited 4x4
Old 11-03-2011, 07:21 AM
njneer1's Avatar
njneer1 njneer1 is offline
njneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to allnjneer1 is a name known to all
It may just need the tracks lubed up
Old 11-03-2011, 09:42 AM
jayc3169's Avatar
jayc3169 jayc3169 is offline
jayc3169 is starting off with a positive reputation.
Quote:
That's what she said!
Ok, I'm sorry, I'm done. LOL
Old 11-03-2011, 10:06 AM
tylerhughes's Avatar
tylerhughes tylerhughes is offline
tylerhughes is starting off with a positive reputation.
Same thing happened to my passenger window when I first bought the truck. Sometimes it wouldnt respond to the switch at all.....I just swapped the motor out with the drivers side rear door since the passenger window gets used more. Lubed up all the tracks but that same motor still has problems with going slow/not working sometimes
Old 11-03-2011, 12:10 PM
dosecobanya's Avatar
dosecobanya dosecobanya is offline
dosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud of
I had the same thing, hit them all with a silicone lube(less mess) and now no problem, but do them all at once. Use the staw, put it in the corner of the track with the window down and spray for about 10 sec. Hope it's that simple for ya.
Old 11-03-2011, 12:33 PM
Skinsfan6's Avatar
Skinsfan6 Skinsfan6 is offline
Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.Skinsfan6 has a very good reputation on FTE.
My driver's side does this also. I changed the motor and it helped none. Returned the motor, lubed the hell out of the felt window tracks with silicone spray. It helped for a day or two until it wore off. I believe the problem lies in the felt having worn off the window tracks on the inside where the edge of the glass rides. I think only a longer lasting lube or new window track will fix it. It really pisses me off.
power window ? Jeff heine 1999 - 2003 7.3L Power Stroke Diesel 1 12-18-2016 04:42 PM
2000 ford excursion SLOW WINDOW!! Daviddc114 Excursion - King of SUVs 22 07-06-2016 10:56 PM
Passenger Side Window Slow Aaron_Jones Excursion - King of SUVs 4 06-17-2016 09:54 AM
Rear window won't go all the way UP ronjeremy6 1978 - 1996 Big Bronco 5 02-09-2015 10:06 PM
Slow Windows... threefiftyone 2007 - 2014 Expedition & Navigator 5 01-13-2010 01:29 PM
Tags
2005f150windowgoesupslow, 2008, driver, drivers, driversidewindowgoesupanddownveryslow, expedition, explorer, f150, f250, ford, side, slow, slowly, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
