Was digging through my 150's ppr wrk folder & ran across a belt sleeve that I think is the one I used to bypass the air pump. Its a Dayco "poly cog" with a primary part# of 5060905 and a secondary # of 6PK2300. If its too short, its for the 5.0 in my 92 GT...
Thanks D. I wrote it down and put it in my wallet! I wish there was money in there and not just paper! I am going to refer to it as a mini briefcase instead of a wallet.
I just did a search, that is for your mustang. it's 90.5" but i looked up 92 Ford Mustang GT 5.0...thats what it gave me.
edit: the factory belt for my 95 351w says 102" and u said( 86. something?) i got it wrote down in the garage. It's at least a starting point!
96.8 I think, its on the other thread. However! I'm pretty sure I have the other sleeve some where. I'll get back with it & you can cross check.
No big deal really. if you find it, throw it my way and if I get a belt I will put the info on here for others future projects.... or if I put the sleeve in the wrong folder... thanks!
