is there anyone who has pictures and torque specs on a valve body in a 5r55e trans? - Ford Truck Enthusiasts Forums
Old 11-02-2011, 05:08 PM
tate89 tate89 is offline
tate89 is starting off with a positive reputation.
I have a 5r55e transmission, that goes to a 97 ford explorer sport trac 4x4. I recentley purchased a reman valve body thats been updated with the seperator plate with bonded gaskets. I just need a picture of the torque specs and bolt pattern. if anyone could help me out i would greatly appreciate it, thanks guys.
4r100 drain plug torque spec r___r 1999 to 2016 Super Duty 4 12-15-2013 07:11 PM
5r55e valvebody torque sequence Chris55 Clutch, Transmission, Differential, Axle & Transfer Case 0 03-04-2011 10:04 PM
Ford Ranger 5R55E valve body diagram. Joe Barth Ranger & B-Series 3 02-25-2011 12:56 AM
r5 44e-r5 55e swapout cheekot1frank Clutch, Transmission, Differential, Axle & Transfer Case 0 04-05-2010 01:07 PM
4R44E-4R55E-5R55E Valve Bodies interchangable atvfan Ranger & B-Series 0 03-25-2008 09:53 PM
Tags
2003, 5r55e, body, bolt, escape, explorer, ford, pattern, pictures, plate, separator, sequence, specs, torque, values, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
