More Fuel System Problems
on
one of the meany things we look at is fuel trims. a change from a trim of 0 to a number that is in excess of +/- 10 would put a trim in double digits. this is a change in the amount of fuel the pcm is commanding per an injector to correct engine running condition.
hope that clears it up
sorry. didnt mean to confuse you.
Values at idle for the seven cylinders I could choose.... varied from worse case of occassional -3 or +4 and some zero; but, while under way on the road they were all zero. So this seems good to me.
I guess if I check them periodically and they take a jump into double digit realm it is time for new truck
Bob
i am having the excact same problem. seems to always happen when i am pulling a load. the ford tech told me the hpf system was going out. he told me it was an $8000 repair. my truck has 115000 miles on it, so no warranty. the only thing i know to do is trade it in. i'm pissed about it because i almost have the truck payed for. I FEEL YOUR PAIN!
I did find comments in an old TSB that all trims go to zero when engine is in regen too.
My only issues are I am still loosing coolant (super slow, but more evident after long towing); oil analysis shows potassium and I have high wear metals. Thinking about installing a piece of SS tubing to bypass the coolant to my old style EGR prior to next oil change; just to rule it out or point the finger. Truck otherwise runs great, pulls great. I am about 200 miles shy of my 65K Mi oil change being due.
I dump a half bottle (16 oz of the 32 oz container) of Diesel Kleen at each fill-up and have been doing so since truck was new. Fill-ups use to be closer to 30 gallons but now closer to 20 gallons as I try to keep it more full since the 1/4 tank starting issue...... plus want to avoid condensate in empty tank on truck I do not drive every day.
I will have to log some driving with the laptop and AE to catch the fuel trims following a regen just to see what is going on. My hope was to have a barometer on fuel system health by perhaps monitoring the trims.
Thanks,
Bob
I really do not have any drivability concerns; I was hoping maybe this could be sorta a indicator something is trending toward the dark side?
Thanks,
Bob
Thanks,
Bob
Mine is around 7.
#30
@ Senix
From Blackstone: "
Potassium, Aluminum, Iron, Mileage
nn..............25.............53... at 40,532
18..............20.............52.... at 46,133
8................21.............35.... at 50,463
71..............50.............101... at 58,746 (yep went a little long)
Changes were at every 10K up to the 40,532 mark in July 09 at which I went to 5 K schedule (except went long on last change) The lab I used up to 40 K was not Blackstone and previous lab did not test for Potassium. Previous lab was Titan.
The last change does include the event in which my heater hose blew off which could explain high aluminum & Iron as engine got hot and went in limp mode (but in my mind I can not tie this to the elevated Potassium.)
I will be changing oil this weekend.
Truck had factory fill first 10K (no fuel dilution)
Mobil Delvac ESP (synthetic) second 10K (greater than 4% fuel plus pipe not clean @ 18K)
Rotella Synthetic ever since... (2% fuel dilution on 20-30K)
no fuel dilution on 30-35K
less than 0.5% last change
Truck was getting about 20K/yr till I quit using it as daily driver. Initially went with 10K till aware of all the fuel dilution concerns. Hindsight is 20/20
If can't get the coolant loss under control I will be trading.
Bob
From Blackstone: "
We found quite an increase in wear from your 6.4L in this report. Aluminum, chrome, and iron all
increased considerably. The only thing that might explain these increases is potassium, if it shows coolant in
the oil. Potassium can also come from the EGR system...."increased considerably. The only thing that might explain these increases is potassium, if it shows coolant in
Bob
