460 help
Running idling
VIDEO0022.3gp - YouTube
Key on not running
VIDEO0023.3gp - YouTube
Running with fuel regulator unplugged
VIDEO0024.3gp - YouTube
Key on not running
hi, first of all that starter sounds awful and is probably drawing too much current, but i think you should try holding the gas pedal down 1/2" and see if starts easily, if so the idle valve/throttle body maybe dirty. there is also the EEC gound wires by the batt negative post.
i have not watched your fuel pressure videos yet, i'll try watching them and see if anything jumps at me. unfortunately a scanner is of little help for this model year of truck because the ecm is not data cappable as far as i know.
NOTE: I"M not a mechanic, i only play one for movies and infomercials.
any ????? call me @ 773 284 5900 ask for crewcabfan.
Thx i thought so to but that is what i was not looking for because i am out of ideas an now my truck will not start it ran great till i turn it off. I fix the takeing so long to turn over now it just wont even crank what the hell next. I am so close to just saying scrap the pos.
if you end up replacing it don't forget to clean the battery ground cable where it bolts to the block.
i dont know if because they are all considered heavy duty and not required
to pass stringent emissions.
i know that all light duty trucks 8600 GVW and under give datastream since 1989 or so.
but then again this is a 93 f250 so it may or may not be data capable.
in mine i had to find a ecm from a 96 f450 for the data capabilities.
#28
#29
the 460 lives here:
i also have a solus and a solus pro, also IDS but that one only works on 96 and newer.
last week i purchased an old snap-on mt2500 graphic wich i'm gonna permanently install in a custom built center console to monitor engine and trans data while on the run.
if i remember correctly you too are doing some kind of big block conversion arent you?
#30
Yes, I'm in the process of converting my 86 F350 crew cab dually to EFI and E4OD. I will ultimately be using a WAY1 ECM so I can have MAF SEFI on a 460. ArdWrknTrk suggested I do a write up, I had not previously as I didn't want to get in a p*****g contest with Uncle Stosh regarding changing an 80-86 model. That's a nice looking truck, I'll bet it surprises a few people.
Last edited by 85lebaront2; 12-11-2011 at 08:38 PM. Reason: Additional lines added.
