need help 1996 ford
The fuel pump primimg at weird times with the engine off was another symptom I had with my truck. Our symptoms were exactly the same. Changed distributor (PIP sensor inside) and everything has been fine. You can change the pip sensor but you have to take dizzy out and have some special tools to remove the gear and put the gear back on. A new dizzy comes with a new pip and it's a pretty easy job to replace. I bought a remanufactured dizzy and it works fine for now. Some others on this forum would disagree and will tell you to buy a new one. I took my chances and have had no problem for a month.
Is the replacement distributor rebuilt or brand new? Many of the so-called "rebuilt" units have bad PIPs in them because the remanufacturer does not heat test it.
Another test you can do is unplug the computer (PCM) then see if you have spark. If you do...it's a bad PCM.
You may need to start tracing down wires. as well. Never overlook the simple things.
I thought this was my problem because when I moved the wire the fuel pump would run and I would get fire, I looked back there and the plastic around the wires was melted but I took the upper part of the intake off and got the wiring harness out and none off the wires are melted
BigEazy619
06-07-2019 08:47 AM
john-h_schmidt
01-28-2007 04:03 PM
