49 F-1 differential ID
Hey guys, I need info from ya, mostly just for curiosity sake..... I'm working on the old 49 F-1 and I finally got to work on the rear differential, removing years of grime and crap off it. I looked at some older post trying to figure out what rear end this is and I came to the conclusion (I think) that its a Dana 41. In the upper left hand of the center of the axle it reads 16429, upper right is a US patent, lower left is a US patent and lower right is stamped 41. It also has a tag bolted to it that reads W 41/11. On the right axle it looks like a stamp that reads 6649A, but is more or less fades toward the "A" and is hard to read so I may be wrong on that one. Ideas???
Thanks!! Will
Thanks!! Will
I believe 3.73 was the standard ratio with a V8 up til '50? At which point they geared down to 3.92 as standard. That's why manure spreaders race away from the monkey faces at stoplights!
The shop manual (the reprint w/52 supplement) only lists 3.92 and 4.27 gears, that's what I was going off of, but I remember someone talking about 3.73's being an option? Each of my F1's had crashbox 4's, 1 6 cyl, 1 v8, and they each had 4.27's. I'd be pretty happy 3.73's, though.
That's why I swapped in the 3.50 9". I'll give you light-to-light in exchange for hwy speeds.
jpwestco
13
04-27-2012 01:10 PM
Mike's old 52
02-05-2011 07:09 PM
terryb4471
04-27-2009 01:36 AM
mikesfordf1
02-23-2005 07:29 PM
