Lifter Size and Bore - Ford Truck Enthusiasts Forums
Old 11-01-2011, 07:10 PM
rpatrick rpatrick is offline
rpatrick is starting off with a positive reputation.
I'm replacing the hyd roller lifters in my 302 and have noticed that I can get them in .874 diameter and .875 diameter. What is the stock size and what is the other size for?
You'd think this was a simple question but the searches I've done are confusing. Some places say the lifter is .875 diameter which implies that the actual bore (hole) in the block is larger.
I have also found posts that say the bore is .875 which would mean I would need the .874 lifter to get it to fit.
Thanks for your sage advice,
RP
Old 11-01-2011, 11:17 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
That is just a 1/1000th of an inch difference, I can't imagine that will make a difference. The manufacturers must just list them funny. Just make sure the part is for the proper application.
By the way, I've never experienced a problem with my hydraulic lifters, are you just being thorough?
It's hard to beat the factory Ford lifter unless your looking for a lifter for a little more RPM. You can get a little more RPM out of the factory one by just putting less lifter pre load in it.
Old 11-02-2011, 10:12 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
My chiltons manual lists the standard lifter diameter as 0.874".
0.875" diameter lifters are likely only used if the bores have to be rebored due to excessive wear.
ticking engine strat875 Modular V8 (4.6L, 5.4L) 2 10-15-2016 03:35 PM
2008 f250 SD lifter noise strat875 Modular V8 (4.6L, 5.4L) 0 09-20-2016 12:00 AM
Fuel tank sending unit lock ring jb10725 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-07-2014 05:20 PM
1972 F100 motor swap 360 to 429 Shane1972 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-08-2013 05:58 AM
Rhoads lifters, what do guys think? vettelvr FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 11-11-2001 04:31 AM
Tags
0874, 0875, 1979, 1996, 30, 302, 351w, 90, bore, diameter, f150, ford, lifter, lifters, size, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
