Truck starts without key, HELP !!!!
Old 11-01-2011, 05:37 PM
fluknick's Avatar
fluknick
fluknick is offline
Hey all
Could really use some input here.
86 f350, 351W, C6, no AC.....
I have replaced the starter ( just figured ), solenoid, put new contacts on all the wires that connect to the batt side of the solenoid.
Have the solenoid wired with ignition wire on "S"..truck starts without key as soon as I connect ground to negative side of battery.
I disconnected the steering column ignition switch harness, truck still starts as soon as I connect negative side of battery.
I removed all wires to solenoid except ignition to "S", solenoid to starter, and batt to solenoid.
Steering column ignition harness connected, truck starts as soon as I connect negative to battery.
Steering column ignition harness DISconnected, truck starts as soon as I connect negative to battery.
I removed all wires to solenoid INCLUDING ignition to "S", with only solenoid to starter, batt to solenoid.
This happened with and without new starter.
To me, this says solenoid but its the second NEW solenoid.
Anyway....thanks for any help.
nick
Attached is pic with wires attached except solenoid to starter....it,s next to...
Old 11-01-2011, 06:22 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
If it starts cranking with nothing but the 2 large battery cables attached to the solenoid, the solenoid must be bad.
Old 11-01-2011, 06:27 PM
fluknick's Avatar
fluknick
fluknick is offline
Thanks Rogue.....
Second guessing everything 'cause of the weird behavior.....
nick
Old 11-02-2011, 09:43 PM
fluknick's Avatar
fluknick
fluknick is offline
Aaaaaaah.....
After smoking up some wires I descided to buy a manual to see if The Beast may have a wiring issue.....
The wiring from alt through to the starter looks nothing like the pic below....
....in fact, I found it hard to believe my truck never once burnt to the ground, let alone ran or even charged a battery !!!!!
God protetcts the unaware, I guess
Ethan Regier
18
10-30-2016 06:05 AM
rustygold1
07-21-2013 12:06 AM
brhine_99
03-01-2010 11:47 AM
ridecolby
Electrical Systems/Wiring
10-13-2007 10:59 AM
76F250HighBoy
11-01-2005 04:14 PM
Quick Reply: Truck starts without key, HELP !!!!
