1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
1962 ford p/u unibody
Old 10-31-2011, 08:45 PM
tricky1948's Avatar
tricky1948
tricky1948 is offline
I have replaced the orginal 6 cyl. 3 spd with a 289 . c-4 a/t and want to use the orginal column , by replacing some of the m/t parts with a/t parts. should be simple. LMC TRUCKS seems to have the necessary stuff. can it be done?? if not does anyone have a stock a/t column for sale? thanks tricky1948
Old 11-01-2011, 05:07 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Moved to uni forum
Old 11-06-2011, 12:30 PM
kjvforme's Avatar
kjvforme
kjvforme is offline
Sorry for the delay on you question. I am currently using my three speed column to work an automatic transmission. The tranny is hooked up the reverse and first. You dont have the indicator but with feel it works out. The detents on the transmission are sufficent to tell you where your at. Mine has a two speed jetaway tranny so having a
C-4 may be a little different.
cookieman69
01-03-2010 04:17 PM
NASTYBLUE
08-07-2008 09:20 PM
thunderb
08-12-2005 07:36 AM
daveengelson
03-01-2005 05:09 AM
jcs1966
05-06-2002 04:43 PM
Quick Reply: 1962 ford p/u unibody
