Interchangeable parts
There is a vintage mustange shop near me that I've been getting parts for my 66 from. The parts guy there isn't very knowledgeable on f100's so he doesn't really know what parts are interchangeable between the two so I was wondering if someone on here knew which parts I can easily swap between the two especially if the wiper switches and motors are.
Semper Fi
Semper Fi
There is a vintage mustang shop near me that I've been getting parts for my 66 from. The parts guy there isn't very knowledgeable on F100's so he doesn't really know what parts are interchangeable between the two.
Some electrical parts are the same, mostly under the hood. Possibly trans parts, depending on which one you have. Besides that, next to nothing is the same.
So I was wondering if someone on here knew which parts I can easily swap between the two especially if the wiper switches and motors are.
Where in CA do you live?
Excepting the wiper blades and the clip that retains the relay arms to the wiper motor, any year Mustang w/shield wiper parts are not the same as 1961/66 trucks.
1966 F100 w/a serial number of 748275.
C3TZ-17A553-E .. Wiper Switch-Four Terminals-Use with Two Speed Wipers (Motorcraft SW-721) / Marked: C3TB-17A553-A or E / Obsolete
Applications: 1963/65 F100/350 & 1966 F100/350 before serial number 760,001.
C3TZ-17A553-G .. Wiper Switch-Five Terminals-Use with One Speed Wiper Motor (Motorcraft SW-722) / Marked: C3TB-17A553-G / Obsolete
Applications: 1963/64 F100/600 use w/Ford wiper motor (not Bosch) / 1965/66 F100/600.
Originally Posted by Broomfieldbum
You can get a switch out of a 79 XLT with Delay, and get Delay wipers.
The intermittant switch: (D1OZ-17A553-A is the the same for all.
EDIT: There are two different governors (modules): D3TZ-17C476-A = 1973/77 / D8TZ-17C476-A = 1978/79.
If there is no switch present, then look at the harness:
The factory two speed connector is a female 4-wire, "Vee-shaped" connector, while the single speed connector is a flat, 3-wire (two female, one male) connector.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
HIGH BUCK!! BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
No other Ford Dealer or obsolete parts vendor has any.
I typed this same info several days ago, as another member was looking for this same switch, so one of the four listed above has most likely been sold.
Make SURE you need the two speed switch, because if it's wrong, you are prolly STUCK with it. Most sources will not take back obsolete parts once they are sold.
And...no one that I'm aware of, will take back electrical parts, obsolete or not.
