Will a 1990 F350 fit on a Uhaul Tow Dolly?
on
Never mind if it fits on the dolly and if the tire straps reach around the tires.. which they may not.. what are you planning to tow that 7000lb truck with?
Here's a little story. I recently rented one of these dollies to move a Ranger we bought and the straps were a fair bit too small for 235/75-15s... don't know if I would try it with anything larger. But that's not the best part, I had to lie to them and say I was going to haul a Fiesta because their software system wouldn't allow the booking with the Ranger.. said it was too heavy for my F150 to tow. It seems the software is based on vehicle weights and they won't book any combo where the tow vehicle is less than about 60% more than the one being towed, and of course the numbers they have for curb weights are way off.. had my truck listed at 4300lbs. Anyway... if you do find a dolly that will handle the F350 come back and let us know how it goes.. and what story you had to use to rent the thing.
I will be towing it with a 94 Crew Cab just like the one I am picking up. It is a F350 Diesel 4x4 also. I rented an orange tow dlly in Salem, OR and hauled a 62 F250 4x4 bck to KY with no problems. I think if the tire straps won't fit I can use my chains and binders to secure it to the dolly as long as the table of the dolly can still pivot.
So no on the u-haul trailer (my friend tried it with his '75 F250 4x4 standard cab, and it didn't work out well - he ended up driving it all the way across the country behind his wife in the U-haul truck) and no on a tow dolly (esp. since most of them don't have brakes).
You could put the transfer case into neutral and flat-tow it using a towbar, but then you would have serious issues with stoping (unless you had somebody riding in the towed rig that could activate the brakes; even without power assist it would be better than nothing).
Uhaul said it had to be 72" or LESS.
The rear end of the truck(from outside of tire to outside of tire) is 74"
How do you fit 74" in 72"?
I just called Uhaul. The wider model tow dolly (assuming that's the newer Silver edition) will tow 75" or less. The older tow dollys will tow 72" wide or less. The 1962 F250 I towed from Oregon to KY fit snugly on a orange Uhaul. The 1962 was 4x4 also. I don't care about the width. Of the body because it's 4x4 so the fenders will be above the dolly anyway. Only the tires need fit. It looks like the silver dolly will just clear.
When towing the 1962 the tire straps fit but just barely. It has the original narrow split rim tires on 16.5" rims. I towed that from Oregon with my crew Cab (backed it on, transfer case in Neutral, unlocked hubs, locked down the steering wheel. I think I'll b3e ok with the wider dolly.
