You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
loads of them on fleabay 6.0l injectors | eBay. , FWIW i heard they no longer manufacture these injectors anymore and that all of them are remans. not sure if that is true. maybe someone can clear that up
__________________
05' silver f-350 lariat 6.0 psd 4x4 crew cab drw, 4"inch turbo back exhaust, BPD oil cooler condenser mount, powermax turbo,dc power 190Amp OEM High Output Alternator , coolant filter, auto meter: boost, coolant temp, trans temp, egt, voltage. scan gauge II, Rds 91 gallon fuel tank toolbox combo, ready lift 2.5 leveling kit, blue spring mod.Fumuto oil drain, AE w/ford enhanced bundle.Air lift 5000 series rear air bags
The thing to remember is that not all remans are created even close to equal. Ford uses NEW spool valves and tests all their injectors for flow and operation. I'm sure that not everyone (or anyone) does that.....at least as far as spool valves are concerned.
__________________
Payin it Forward one post at a time
I look at it like this: The advice is free and you get what you pay for; use it or dont my truck still runs fine. From a very well respected friend....Thanks
Even international???
__________________
06 F-350 6.0L 102,000miles ARP Oil & Coolant Bypass Filters + EC-1 SCT IDP Delete Pipes Edge Insight STC & Fuel Reg Update Pluged Up-pipe No ScoopFront 2" Hitch 2.5" Front Lift Firestone Air Bags Front E-Locker Rear ARB Locker
__________________
2006 F350, Bulletproof egr cooler, home made coolant filter, STC, standpipes and dummy plugs updated, blue fuel pressure spring, CCV reroute, glowshift guages, VXCF9 strategy, 325/65/R18's, 345,000 km, will keep updating as they add up.
I bought mine at Oregon Fuel Injection. They had a great price, about $50 less than Ford, and I believe they are Alliant rebuilds just like Ford uses.
Ford does NOT use Alliant rebuilds
__________________
What is Ford's source? You know they don't actually rebuild their own.
That's a good question. I know that Cass went from Alliant to Motorcraft because he had too many problems with Alliant's injectors that are nonexistant with Motorcraft.
__________________
I am FINALLY in the frame of mind (and wallet) to attack an issue I've been dealing with for exactly (to the week) TWO YEARS now...my local Stealership replaced my #2 injector and it worked great for about 3 months...
Code reader (SCT Livewire system) throwing a "contribution" code for #2 and when I took the truck back at 4mos. they said "whenever you want to bring it in" - well, I was building a new home/shop and figured I should take it in 2 weeks shy of the 12mo./12k mi. "warranty".
The service rep. immediately said, "you're at 12,4XX mi. over the 12,000mi. warranty" and that was that...they HOSED me...Ford "Customer Care Solutions" said they couldn't do a thing for me so here I am, a year later, settled in the new home/shop and ready to rumble with changing out #2!
I happened upon an awesome Youtube video of a Ford Master Tech. who shows you how to do all sorts of procedures, namely the injector changeout on a 6.blow - I feel I can do this, after all, I am a "race car guy" and have an awesome set of tools.
Some of my questions are:
Should I really buy the bomb-diggity Motorcraft "Injector Cup Cleaning Brush" at $50? I don't hear much mention of it on here, but then I haven't read EVERY post regarding changing injectors.
Is it common sense to change the copper seal, oil rail seals and of course, the O-rings on all the injectors on that bank?
My best guess is that they didn't clean the injector cup, I KNOW they didn't change the copper seal at the bottom of the cup (at that time they told me they don't) and probably didn't brush/blow out the bolt hole - so there's a decent chance the injector isn't all the way seated and I've driven for 2 years and probably 20k mi. with it like that.
It's now getting colder and the truck really "talks back" during my morning commute - it's horrible until I've been driving for a good 5min. after at least a 10min. warm up...my new neighbor HATES my truck...they're retired and have to listen to it warm up every AM...going to start plugging it in.
Any other tips to consider before I take this on? It appears pretty straight-forward and everything the tech. mentioned in the video makes complete sense, PLUS what I've read on here over the years.
Which injector installation write-up is the best/most recent? Can someone link me to it? Thanks again for reading/enduring my long posts...it's been a good year since I've been on here but it's time to get back to business now that we're settled into our new home.
__________________
Jeff Curtis
'08 F250 SD Lariat, 6.4 Auto, Off Road Package, DPF Delete (DO IT!!) Mini Maxx tuner, Banks Intake, MBRP 4" Turbo Back "Race Pipe" (nice sound, amazingly quiet)
'06 Porsche Cayman ITC P2 / NASA GTS3 / PCA GTB2
My 1st FTE Photo Album! - http://www.ford-trucks.com/forums/album.php?albumid=241
Racecarhauler--new/reman injectors come with the copper seal and o-rings already installed, so replacement by the dealership shouldn't have even been an issue. AFA cleaning the injector cup, all I've ever done is cleaned them with towels however is you have one leaking exhaust then it's possible you'll need the tool. Installing the copper crush washer should be done every time you pull and replace an injector. The o-rings I've reused with no problem but they come with the kit so why not use them. Changing them on every injector on one bank just isn't necessary.
If the injector wasn't seated into the cup properly the truck probably wouldn't be running enough to drive.
__________________
