Creaking Sound When Turning Steering Wheel - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-01-2011, 12:24 PM
kass kass is offline
kass is starting off with a positive reputation.
Hey guys. Own a 2003 Ranger, 4WD. 123,000 miles, all original factory except for plugs, brakes, Ford OEM condensor (dealer installed), and passenger airbag turnoff switch.
When I turn my steering wheel, I get the creak. Sounds like it is from inside the cab. Before I posted, I read many of the similar posts on the site. I know I am due for new ball joints, but could the squeak be coming from steering column despite well worn ball joints?
Thanks.
Old 11-01-2011, 01:10 PM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
I have the same issue. I think it's just something in column that needs to be greased
Creaking 2wd 06 F350 firedaniel 6.0L Power Stroke Diesel 2 04-04-2015 07:31 PM
steering problem Hawkline 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-27-2012 12:46 PM
Creaking noise when wheel is fully turned left MoreBoostPlease Excursion - King of SUVs 9 07-14-2011 05:10 AM
Got a bad case of steering creak... superrangerman2002 1997 - 2003 F150 11 12-21-2009 08:35 PM
Creaking in front end while turning when not moving dcaprio 1999 to 2016 Super Duty 15 05-28-2009 01:32 AM
Tags
03, bumps, charger, creak, creaking, expedition, f150, ford, noise, ranger, sound, steering, truck, turning, turns, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
