to wide tires on dually
On my 1999 dually I run 305-70-16's on stock rims . I had to get some spacers to do it ,I found a guy out in California an ex - drag racer that makes very high quality ones . Mine were hub eccentric yours should be lug eccentric .Ford Truck Enthusiasts Forums - 1996pwrstrk's Album: Dually adapter
This is Fred's link check his site out and give him a call he's a real nice guy ,if you want to go the spacer route WheelAdapter.com > Wheel Spacers
Yep, VERY BAD thing, I seen the end result of tire sidewall rubbing, a totaled truck and a munged up friend. He got a set of new tires on his dually chevy, the biggest he could find. Only 10-20 miles he went before the sidewalls blew out flipping the truck! The other set was almost ready to blow out too. FHP investigation found the sidewalls were rubbing and there was some brew ha ha over it.
