TFI module
TFI module
My frigin radiator hose is in the way of my tfi on the distributor. If I set the base timing at 10 degrees btds. My tfi is slammed up against my rad. hose. Something doesn't seem right. I twisted the hose more upright and that seemed to help a little. Did I put the distributor in wrong or something? It seems to idle correctly.
My buddy Sackman has a great write-up on another forum: How to properly set the timing on a 302 or 351 - FSB Forums
You are close enough now, all you need to do is take off the hold down bolt, pull up on the distributor just enough to move the rotor/distributor shaft one tooth, then drop it back down. Then reset the timing. I assume you also pulled the SPOUT when you set the base timing?
Scott's write-up works pretty well if starting from scratch.
