Scanguage II on Amazon.
Old 10-31-2011, 09:34 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
ROBBINthaHOOD is offline
If anyone is still looking for a scanguage ii, Amazon has them on special for 149.95 with free 2 day shipping for Prime members. Says Im guaranteed Wednesday delivery. Have been needing to get one to diagnose some glitches on my 05' and this is the cheapest I have been able to find one. Thanks for everyone posting the x-guages for these devices.
Old 10-31-2011, 09:40 PM
tonefordays's Avatar
tonefordays
tonefordays is offline
I just ordered one today. Can't wait to get it.
Old 10-31-2011, 09:48 PM
ROBBINthaHOOD
I came across a "spreadsheet" of x-guages for the 6.0 on dieselstop.com (I think that was the site, I hit a link on google). I know to monitor the ECT and EOT for sure. I dont want to input alot of x-guages that I will more than likely never use. What are the most common or crucial ones besides those two that I need to have programmed in. I will be adding a fuel pressure, egt, and probably boost on a pillar gauge as money permits. Is the boost guage on the scanguage fairly accurate as opposed to the dial type guage? Thanks guys.
Old 10-31-2011, 10:51 PM
NewToDiesels's Avatar
NewToDiesels
NewToDiesels is offline
The list below was compiled by amdriven2liv and those are his notes. I highlighted in red the X Gauges I consider to be essential to monitor the health of my engine. I watch all of these at one time of another to make sure everything is ok. Others may have a differing opinion obviously.
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Old 10-31-2011, 11:27 PM
ROBBINthaHOOD
Much obliged. I cant wait for it to come in so I can toy around with it and check some things. I have been having a hard start issue lately. The truck died the other day as soon as we pulled in the drive and would not start back up, it would crank over just fine just never start. I havent tried it since but I want to be able to run some values on some things and see if I can pinpoint where the issue is. The truck was running fine, I thought my wife turned it off but she said it died on its own, there never was any hesitation going down the road so Im curious to see what I find out.
Old 11-01-2011, 01:07 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
05 f250 6 inch lift is offline
Newtodiesels. Thanks for that list. I will b addin more to my x gauge tomorrow. I habmve ECT. EOT. TFT in it now.
Old 11-01-2011, 01:39 AM
desertnomad's Avatar
desertnomad
desertnomad is offline
Old 11-01-2011, 08:25 AM
NewToDiesels
You'll defintely want to look at your IPR duty cycle % while cranking, also your ICP voltage (needs to be .8 volts or greater) and ICP pressure (needs to be > 500 PSI to start). Looks like you have an 05 model and the no start may be related to the HPO system. Another clue is if it starts great when it's cold and not so well when its hot. It's probably your STC fitting on the HPO pump leaking.
Old 11-02-2011, 01:17 AM
GeneLaw1's Avatar
GeneLaw1
GeneLaw1 is offline
Sometime my IPR can be 21 or 22 when at hot Idle? Is that a problem?
Old 11-02-2011, 02:11 AM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Don't think that would be a problem. Seems mine runs around there also. Some of the readings from Ford don't quite match up. My ICP low idle is around 585 most of the time, and I have seen others say the same.
Could be oil type?
Old 11-03-2011, 12:48 PM
CARV's Avatar
CARV
CARV is offline
Thanks, I should get mine in the next few days
1986F150six
02-13-2017 09:41 AM
Tylus
1999 to 2016 Super Duty
67
05-13-2013 03:37 AM
HarleyFXDL
Vehicles for Sale
03-31-2010 07:14 PM
zx250
23
07-05-2009 05:49 PM
mmjax25
1997 - 2003 F150
04-21-2008 07:17 AM
Quick Reply: Scanguage II on Amazon.
