Suspension noise - Ford Truck Enthusiasts Forums
Suspension noise
Old 10-31-2011, 10:10 PM
txbest1980 txbest1980 is offline
txbest1980 is starting off with a positive reputation.
Suspension noise
I have a creeking/squeaking noise in my suspension that is getting worse and worse. maybe it isnt getting worse, but it sounds worse to me everyday because I am tired of hearing it. I have swapped out my shocks and that did not do the trick. i have tried lubricating the leaf springs and all other suspension parts in there, still nothing. i was thinking about changing out the entire leaf spring package, but do not want to waste any more money until I have a better idea of exactly what the problem is. any help would be much appreciated...
Old 11-01-2011, 08:53 AM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
Does it sound more in the front or rear?
Old 11-01-2011, 02:09 PM
CollinF's Avatar
CollinF CollinF is offline
CollinF is starting off with a positive reputation.
you check the plastic pads between each leaf?
Old 11-01-2011, 07:59 PM
sounds more like the front than the rear...
the plastic pads are still there, a little worn but there none the less
it makes the noise when i am turning the steering wheel right or left and going over bumps. it also happens when the weight shifts from stopping and taking off
Old 11-01-2011, 09:43 PM
00GT's Avatar
It sounds like a broken sway bar link or bad ball joint. When you replaced the shocks, did you replace the lower bolts too?
Old 11-01-2011, 09:50 PM
i did not...maybe i will put the truck back up on a lift and look at the sway bar links and ball joints...i know i want and need to get rid of this damn noise cause it is driving me nuts
Old 11-01-2011, 10:03 PM
00GT's Avatar
Bad ball joints will give you that squeaking noise when you turn right to left. A broken sway bar link will give you that bumping noise when you stop and go. Also the front lower shock bolts get worn down and have some play up and down. That will also give you a bumping noise. I just went through this on my screw I replaced everything in the front end And I was still getting a bumping noise, so I replaced the shocks and new bolts from advance auto...noise is gone...drives like a new truck.
Old 11-01-2011, 10:12 PM
do you have to buy the bolts seperately? i do not remember if mine came with new bolts
Old 11-01-2011, 10:54 PM
00GT's Avatar
No the bolts are not included. I got these at advance. Part# 9060561
M12-1.75x90mm. These are perfect fit!
Old 11-01-2011, 10:56 PM
oh okay, thank you very much for the help...i will try and get some tomorrow and see if this works for me
Old 11-02-2011, 06:55 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
Take a needle grease fitting and stab the lower ball joints pump them full of grease
Old 11-02-2011, 10:56 PM
got the truck on the lift today and the sway bar bushings looked to be in decent shape and the ball joint bushings looked to be in the same shape. i did look at the bolt at the bottom of those shocks and there dont seem to be noticeable play, but still plan on trying to change them out...
kbsupercrew...did you have a similar issue and pump grease into the ball joints and solve the issue? i actually considered pumping new grease into all the grease points on the truck today while it was on the lift, but left my damn grease gun at home and the hobby shop on base couldnt find the fittings
Old 11-02-2011, 11:13 PM
00GT's Avatar
Are the ball joints factory? Normally when they squeak there on the way out. You can hit them with the needle and it will quite them down. I replaced mine all with moog. A much better part then OEM. Plus you can grease them.
Old 11-02-2011, 11:15 PM
deljer55 deljer55 is offline
deljer55 is starting off with a positive reputation.
I had a similar issue that turned out to be the front U-Joint on my truck. I changed the front and rear and all was quite again
Old 11-02-2011, 11:22 PM
with all these different suggestions out there, my fear is coming belief faster and faster...i just need to keep replacing parts until i find it on my truck. good thing about it all is, it generally isnt to bad for the bushings and some of the other parts as well. thanks guys for all the help and please keep the comments and suggestions coming
need to lift up rear or X 4", add a leafs or new leaf springs. davefrommd Excursion - King of SUVs 14 02-12-2017 11:23 PM
leaf spring plastic bushings/spacers a tips DarrellinCeres Brakes, Steering, Suspension, Tires, & Wheels 2 10-06-2016 04:19 PM
Need Advice - 1997 F250 LD Air Suspension - Can I just remove and upgrade to leaf springs? EdLennon 1997 - 2003 F150 3 07-28-2016 06:09 PM
Engine ticking noise that's getting worse Gloz 1997 - 2003 F150 3 12-13-2015 07:45 PM
Rear suspension help? Last Triumph 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-30-2015 10:07 AM
Tags
03, 97, creaking, explorer, f150, f250, issue, mountaineer, noise, noises, slowly, sound, squeking, suspension, trailers, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
