Suspension noise - Page 2 - Ford Truck Enthusiasts Forums
Suspension noise
Old 11-03-2011, 01:03 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
2WD or 4WD truck? You never said.
Roughly how many miles?
Can you make the noise by bouncing the truck front or back?
Does the joint on the end of the Pitman Arm have a Zerk, or is it a sealed joint?
Old 11-03-2011, 08:19 AM
cara3321 cara3321 is offline
cara3321 is starting off with a positive reputation.
Is it on a 97 thru 02 f 150 or expedition if so check the Mac strut connections on top shock towers. Those bushings get real noisy.
Old 11-03-2011, 08:35 AM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
I had the same issue I would hear a creaking noise when turning slowly like in a drive-thru, and on my road since it is gravel with potholes bouncing up and down, mine was the lower ball joints after checking everything else, pumped grease thru the plastic cover at it disappeared , there on the list for changing, but Im still working on the engine
Old 11-03-2011, 04:18 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Quote:
These trucks have front shock absorbers and have never ever come with McPherson struts. No bushings to worry about like you are suggesting.
Old 11-03-2011, 09:11 PM
txbest1980 txbest1980 is offline
txbest1980 is starting off with a positive reputation.
it is a 2wd 03 King Ranch...i can not duplicate the noise when i bounce on the truck from side to side, havent really tried front to back...
the more kbsupercrew post, the more my problem sounds just like his...i hear it while in a drive thru turning slowly and when i am hitting potholes and such...i am going to try and squeeze some grease in those ball joints and see if this cures my problem
Old 11-03-2011, 10:50 PM
00GT's Avatar
00GT 00GT is offline
00GT is starting off with a positive reputation.
Oh...you have a 2wd. Then the lower shock bolts I don't think wouldent be your problem. I have a 4wd. I bet ball joints.
Old 11-03-2011, 11:57 PM
Podaso Podaso is offline
Podaso is starting off with a positive reputation.
I just had all of the teflon tabs replaced in between each of the leaf springs on my F150, but bouncing on the rear bumper I could distinctly tell that that was the problem. Mine squealed everytime I hit a bump or turned a corner. Turning the radio up fixed the problem for a while, but I finally had them changed out. Silent now.
Bounce on the front and rear bumpers and see if you can hear anything.
Old 11-05-2011, 08:34 PM
when bouncing on the front or rear bumper i get no noise at all...havent had time to throw it on the lift yet to fill the ball joints with grease yet, but hopefully Monday or Tuesday
Old 11-06-2011, 12:05 AM
2 wheeler has shocks
Yes the 2 wheelers have regular shocks but the 4x4's have a tortion bar with a set up where there is a turning point that gets dry and noisy. It's been a number of years since I've seen one.
Quote:
Old 11-06-2011, 12:50 AM
00GT's Avatar
97-03 4x4s still just have plain ol shocks. I think the 04' 4wd have coil over strut.
Old 11-15-2011, 02:46 PM
well it is back to the drawing board again...
today i threw her up on a lift and i greased it all up. while under there, i got to pulling on things and trying to make it squeak. well when i pull down on the passenger side it creeks and squeaks like an old antique. on the driver's side it doesnt make a sound. the noise on the passenger side seems to be coming from the spring making metal to metal contact at the bottom.
any thoughts or comments will be much appreciated
Old 11-19-2011, 03:37 AM
update...as i have paid more and more attention to this annoying creaking sound that is just getting worse by the day to me it seems...when i had it on the lift the other day it only made the noise and the passenger side when i pulled hard on the sway bar. two things i have noticed since, is when i am turning to the right it makes the noise and it also seems to pull to the right now as well. so i am starting to think that the steering has something to do with this damn noise, but i just can not pin point it exactly...
all suggestions/thoughts welcomed
  #28
Old 11-19-2011, 10:26 AM
When I was seaching for my noise I sprayed inner slide lube (stuff I use at work) on every possible moving joint I saw, rubber grommets and all, up the shocks etc. until I noticed a difference when I soaked the lower joints thats when I stabbed it with a needle joint ( keeping in mind it took several times to get the grease in there) , then I bounced on the rear bumper to really get the front end moving to work it in.
  #29
Old 11-19-2011, 11:49 AM
kbsupercrew...appreciate your response, i will definitely get it on the lift again and just get to greasing it all up again
  #30
Old 12-26-2011, 12:54 PM
update...well i still have not been able to find the noise and it is still driving me crazy. so i am going to go ahead and buy a master bushing kit and just replace all of it and hope that helps. i will update once i get this and installed within the month
Energy Suspension Hyper-Flex System 4.18122G - Energy Suspension Parts & Accessories
they have these kits at autozone and other places, this is just the cheapest i have found it
leaf spring plastic bushings/spacers a tips DarrellinCeres Brakes, Steering, Suspension, Tires, & Wheels 2 10-06-2016 04:19 PM
Need Advice - 1997 F250 LD Air Suspension - Can I just remove and upgrade to leaf springs? EdLennon 1997 - 2003 F150 3 07-28-2016 06:09 PM
Engine ticking noise that's getting worse Gloz 1997 - 2003 F150 3 12-13-2015 07:45 PM
2002 F-250 7.3 4x4 Suspension rattling cokewithvanilla 1999 to 2016 Super Duty 3 11-27-2015 09:52 PM
Rear suspension help? Last Triumph 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-30-2015 10:07 AM
Tags
03, 97, creaking, explorer, f150, f250, issue, mountaineer, noise, noises, slowly, sound, squeking, suspension, trailers, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
