No heat! - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
No heat!
Old 10-31-2011, 08:55 PM
wanta79's Avatar
wanta79 wanta79 is offline
wanta79 is starting off with a positive reputation.
No heat!
My son just bought a 94 ranger with 140k miles. It runs ok but he has no heat in the cab. Checking the coolant tonight and found it to look like chocolate milk! So a flush is definitely in order but that still doesn't explain the no heat issue. Both of the heater hoses going to the firewall are not warm at all and feel like they are empty?? What causes these hoses not to get hot? Also the t-stat was just changed.
Thanks!
Mark
Old 10-31-2011, 10:08 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
Almost sounds to me like the radiator is plugged up and you're not getting any flow... What does your temp gauge say after it's warmed up?
Old 10-31-2011, 11:47 PM
speace91 speace91 is offline
speace91 is starting off with a positive reputation.
I'm having the same problem, except I get heat about half the time. I flushed the fluid and it didnt help anything. My Temp gauge reads normal like it should.
Old 11-01-2011, 12:19 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
Wanta, try giving the cooling system a good flushing. It sounds like the entire system is plugged up.
Old 11-01-2011, 06:55 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
do a good flush as stated. Trucks with AC have a heater control valve. this valve uses a vacuum and shuts off flow at the heater hoses to the heater core. Check that it is working. You might want to swap in new heater hoses. they can get clogged up. back flush the heater core too. I recommend Motor craft tstats.
Old 11-01-2011, 07:09 AM
wanta79's Avatar
Thanks for the replys....going to try and flush the entire thing this afternoon after work. I'm really thinking that it's clogged up because last night I opened the petcock on the radiator and there was barely a dribble of coolant coming out.
If it is clogged, what is the best method of flushing the system? I was thinking of putting a tee in the heater hose a doing it from there.
The temp gauge reads about middle of the "normal" range when it's warmed up.
Where is the heater control valve located and is this something I can test at home?
Oh, and I forgot, it's a 3.0 V6, 2wd, A/T.
Old 11-01-2011, 07:31 AM
Napa sells a Product by MAC that works good for flushing.I would spend the $10 for new heater hoses and change them first. I bet they are filled with crap. Your truck sounds pretty nasty. I would disconnect the heater hoses at the heater core and connect them. that way the crap will not clog up the core any more than it is already. You can back flush the heater core separately. I would pull the bottom radiator hose off and flush that all out before I started the truck. Get as much crap out before you flush the engine out when it is running. You will have to run the truck to full operating temp with water in a few times to get all the crap out. the heater control valve should be inline with the heater supply hose you can see if it is opening an closing when the AC is on. Go to Rockauto.com and you can see what it looks like. Ideally removing the T-stat during the flush is best not necessary. The goods news is that if your heater core is trashed it is a cheap and easy fix. Any Rangers after 1994 you have to pull the dash to replace the heater core.
a good signature helps a lot. If from the 1st post you had a detailed signature that included if you had AC and what transmission you had we would have know if you have a heater control valve and if you had a 5 speed we would know that pulling the radiator is a POC.
Old 11-01-2011, 06:15 PM
wanta79's Avatar
Pretty sure its the heater core now, flushed entire system really good and refilled. After it reached normal temp I felt the heater hoses to and from the core. The one going to the core was hot and the other was cold. Have one ordered, and it'll be in tomorrow.
Thanks to everyone for your help!!
Old 11-02-2011, 08:50 PM
wanta79's Avatar
We have heat!
Well it was a very clogged eater core! Changed it out and burped the system, all good now.
Thanks to all for the help!
~Mark
Old 11-02-2011, 09:01 PM
B 3000 B 3000 is offline
B 3000 is starting off with a positive reputation.
Yes I would say it's your heater core. Years ago I had a chevy S 10 & had the same problem.
Good luck on the replacement.
Old 11-05-2011, 06:14 PM
rangerskip rangerskip is offline
rangerskip is starting off with a positive reputation.
ranger - no heat
Thanks all for the tips & insights.
I too went through the entire cycle of replacements -water pump & thermostat.
I could not get any flow through the core. I COULD pass water directly from a garden hose through the core & no leaks were noticed inside. I put a ~6" section of clear plastic hose in-line with the heater core line back to the thermostat housing. This proved the no flow. I put the front end up on ramps & this got the 'air lock' out of the core & the water flowing. The heat is good.
I hope this helps someone else from all the testing & guesswork.
Old 11-06-2011, 06:40 PM
Uncle Steve Uncle Steve is offline
Uncle Steve is starting off with a positive reputation.
I put in a new heater core and never had heat since. Saw this thread and went to checking. Thought I would check the valve for obstructions. Now my valve is bad. The nipple broke as I was pulling the hose off. Now I will know if it was the valve?
Old 11-06-2011, 07:09 PM
Furyus1's Avatar
Sounds like you need to replace the valve anyway so if, after you replace it you get heat, I'd say that would be a good indicator the valve was the culprit.
Old 11-06-2011, 11:06 PM
I was sort of mad at myself for breaking it. But it has to be original so it was probably due for a replacement . Plus I found Oreilly has it for less than $30.
This darn thing just keeps messing with me. Put in a new heater core this spring, new clutch slave cylinder and clutch during the summer. Drove it home from the shop and the ignition actuator crapped out. Got it replaced and now it's the heat.
Old 11-07-2011, 01:20 AM
michigan66's Avatar
Thanks for the feedback. Its good to lnow that your colling system problem is solved
How does heat work on the heat and cool seats? babybober 2017 Super Duty 13 12-07-2016 12:49 PM
99 Expedition 5.4 no heat Buckland14 Modular V8 (4.6L, 5.4L) 1 11-10-2016 07:28 PM
1999 Expy 4.6 Heat FIXED! - You won't believe how! developer Expedition & Navigator 8 02-03-2015 09:33 AM
Cab takes forever to heat up granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 12-13-2012 03:37 PM
Winter Plug in heater options? WhiteBeast-05-powers 6.0L Power Stroke Diesel 4 09-20-2011 11:44 AM
Tags
1997, 2000, 2002, 2004, core, f150, f250, flush, ford, heat, heater, plugged, ranger, truck, trucks, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
