4.9 dipstick problems?
Old 10-31-2011, 06:35 PM
red93's Avatar
red93
red93 is offline
it kinda sounds weird but the other day i gave my 4.9 an oil change and i also changed the oil pan gasket when that was done pored 5qts in (what the manual said) started it up no leaks drove it around to let the oil warm up and when i checked the dip stick it read 1 qt low checked it again today its exactly on the one qt low line (there is still a slight oil leak). this is the first oil change i have done to it since i got the truck and it was always in the safe zone before so am i supposed to have 6qts in it or is the dipstick wrong. i would appreciate any help
Old 11-01-2011, 12:00 AM
jem44357's Avatar
jem44357
jem44357 is offline
Welcome to the forum
Six quarts, with a filter change, is all I have ever known for a 300/4.9.
Jim
Old 11-01-2011, 09:56 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Yep, if you changed the filter, you need to put in another quart.
So, 1 more in and you should be good to go.
Old 11-01-2011, 11:24 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
6 cyls, and 6 qts of oil. Makes it simple to remember.
06greenstroker
6.7L Power Stroke Diesel
13
03-26-2017 07:18 PM
leebrown5
18
05-26-2012 06:17 AM
lbrauer
04-18-2010 07:25 PM
Baxtjh
03-12-2010 05:20 AM
hecticgb
10-28-2000 08:43 PM
Quick Reply: 4.9 dipstick problems?
