solenoid pack - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
solenoid pack
Old 11-02-2011, 05:17 PM
omanalansan omanalansan is offline
omanalansan is starting off with a positive reputation.
Muekstar - I'm confused with Step 3 and 4, testing pins 1 and 4. Step 3 says on/off and step 4 PWM. Am I testing the same pins ??? I hope i'm making sense
one more question, You think i would need to remove the solenoid pack to test or can I just test while its still installed
Old 11-02-2011, 06:17 PM
trackspeeder's Avatar
trackspeeder trackspeeder is offline
trackspeeder is gaining momentum as a positive member of FTE.
Do the PWM test. You have this pack.
The on/off test is for a different unit.
Kind of a pain without an adaptor harness. but you could test in place.
Old 11-02-2011, 08:33 PM
Thanks trackspeed
Old 11-02-2011, 10:39 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Quote:
Originally Posted by omanalansan View Post
Wow, where did you get this info from?
I'll take you out to a steak dinner after this. ha!
Thanks meukster
I scanned the info from my ATSG rebuild manual.
I bolded (just above the first attachment) the info about using the PWM (pulse width modulated) version of the test in my post. Sorry, I didn't explain that there were two types of TCC application.
It is pretty difficult to access the connection. If you had a pigtail from a donor vehicle, it could be done more easily while installed.
Old 11-03-2011, 12:50 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Thanks Roland.
I looked for the procedure that was sent to me via email (Company wanted the trans shop to follow strict procedure for warrantee coverage), but it was so many years ago, I guess I didn't save it like I thought I had.
Stewart
Old 11-03-2011, 08:52 AM
Thanks guys for your help!!! Man i wish I had a donor pigtail so i woulnd't have to drain the ATF and pull the trans pan.
Anyone know where i can buy a pigtail?
Thanks again guys.
Old 11-03-2011, 10:11 AM
mueckster's Avatar
You can get a new pigtail from Ford for around $40. Ford# 3U2Z-14S411-VCA
Motorcraft# WPT-590
It can also be purchased here. E40D 4R100 transmission wire harness Ford transmission solenoid harness
There are also a few listed on ebay. ford econoline suspension | eBay
Old 11-03-2011, 11:35 AM
Roland - Thanks for the tip. Just found one for $42 and they said i can return it after i'm done.
beautiful. Hopefully I can test the ohms without splicing.
Old 12-08-2011, 09:14 PM
rgore1231 rgore1231 is offline
rgore1231 is starting off with a positive reputation.
Solenoid Block Testing
Can anyone help this Newbie? I tried to check the resistance on a solenoid block that is out of the transmission. The only reading I get is across the thermostat. All the solenoids read 000. Does that mean all my solenoids are shorted out?
E40D: The Importance Of A Clean Trans Harness. FORDF250HDXLT Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-28-2016 01:04 PM
Please begging someone helppppppp nick_ct_203 Expedition & Navigator 24 01-14-2016 03:22 PM
E4OD solenoid pack redman84 1994.5 - 1997 7.3L Power Stroke Diesel 16 09-17-2015 09:19 PM
E4OD Questions 2wd 4wd enosez 1987 - 1996 F150 & Larger F-Series Trucks 4 06-11-2015 07:23 AM
Solenoid pack swap therigwelder 1999 to 2016 Super Duty 0 11-07-2014 10:39 AM
Tags
2000, 2002, 2006, 4x4, 73, aviator, cheap, cost, diesel, explorer, f350, ford, gas, pack, solenoid, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
