Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-30-2011, 06:47 PM
eddiemoney eddiemoney is offline
Garage is empty, add now
eddiemoney is starting off with a positive reputation.
Very odd hum/whistle
Very odd noise, need some help figuring out if I need to attempt to have the dealership recreate.....could be a long process.
2010 22K miles; EL 4x4
When driving on interstate (anywhere between 60 and 75) at times a hum will start (probably every third trip). It sounds like it comes from the passenger side. Its reasonably loud. When I accelerate hard it goes away, when I coast or have really light acceleration it comes back. Its a solid hum/whistle...it doesn't change pitch.
Any ideas? Anyone seen something like that?
  #2 (permalink)
Old 10-30-2011, 07:54 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
check that your e-brake is releasing
4x4? if so, check that your auto hubs aren't engaged. if the vacuum line or solenoid fails your hub will engage (auto fail position is engaged)
best of luck. I know how annoying it is to try and track down a noise
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 10-30-2011, 10:00 PM
ebrake is releasing, i can hear that.....
Last 4x4 I had before this one was get out of the truck and turn the hubs...how in the world would I check to see if the hubs were engaged?
  #4 (permalink)
Old 10-30-2011, 11:06 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
jack up the front of the truck with the motor running
spin both of the front tires. if the front driveshaft rotates, or tries to...it means you have a hub that is failed, or the some part of the vacuum system has failed.
after you hear that noise, pull over really quickly and do a touch test of both rear rims. if the e-brake is dragging on either rear wheel, the rim will be rather hot. You may hear 1 side dis-engage, but it's better to be for certain. the 07+ Expy is based on the 04-08 F-150. The 04+ F-150 has a bad habit of having the rear e-brake freezing up.
__________________
  #5 (permalink)
Old 11-04-2011, 12:54 PM
TFWcustoms TFWcustoms is offline
TFWcustoms is starting off with a positive reputation.
What i had happen with mine was that the rotor cover was rubbing against the rotors, this is caused if you recently swapped tires and the cover was slightly bent. All you have to do is hit it hard enough back
Tags
2010, expedition, ford, noise, odd, whistle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
