DIY, Free/Nearly free Mods Thread
#46
on
If you don't have one originally a license plate bracket is nice. On our 02 with 05 bumper we just used a 02 style license plate bracket. It pushes out more but I personally like it better then the stock 05 license plate bracket. Mine I got for free but I don't think they are very expensive.
Another thing I like about it is it blocks things from getting in that small opening and it doesn't affect the fog lights.
These are $55 on the internet if you search the product and they are a great mod. They were on the truck when we got it. They are called slide and locks made by Hi lift I believe. They are overall very strong and I use them all the time plus they can be slid where ever needed. Actually I trust these more then the stock tie downs in the bed. I personally never cared for ones in the bed sides or ones that you loosen by hand then move and tighten as usually the bed rails bend and it messes the covers up.
Trav
Here is the link: Hi-Lift Slide-N-Lock: Tie Down System for Trucks, Trailers, Jeeps, SUV's, and more! | Hi Lift Jack Company
Trav
#51
Cheap Mod
I noticed I had a few valve stem caps missing so here is a cheap mod I just did. Aluminum valve stem caps $0.99. Cant beat that one cheap.
here is the link.
4 x Silver Fluorite "Hex" Tire Air Valve Stem Caps Car Truck ATV Wheel Rim | eBay
here is the link.
#53
on
here is the link.
here is the link.
Trav
#55
on
Trav
#56
A 99 cent valve cap breaking a 100+ dollar sensor doesn't make any sense to me.
#58
on
Most of your good techs take them off and replace them because they corrode and very stuck the valve stem. This is more so with the newer vehicles with bolt in tpms sensors. When I replace the stems I will not put those aluminum caps back on because it just causes more issues then solves. However I will hand then to the customer and repeat what I've said here and leave it up to them but it doesn't leave the bay with aluminum on it
Trav
#59
It doesn't affect the sensor it self, it affects the stem. it corrodes and gets to the point that when you go to remove the valve cap it snaps the metal stem, or it allows moisture inside and when you go to remove the core it snaps the core. Both make the sensor useless for holding air, requiring it to be replaced because the stems are not replaceable. The sensor itself still works, we use one as a thermometer for the bay.
#60
I'm going to assume you check your pressure regularly or don't have the quantity of salt that they run in my area. It happens pretty regularly if the customer doesn't run a stem or they have those aluminum deals
