Oil leak!!
Old 10-30-2011, 05:02 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
Oil leak!!
Well, I have a oil leak that has been kicking my butt for the past couple of months. It is leaking out of the clutch cover. So, I removed the clutch cover and had my dad rev the engine while I watched underneath and I found that when the engine is revved, oil shoots at the starter teeth and then leaks inside the belhousing.
Any ideas?
Is my block cracked?
rear main?
flywheel bolts leaking?
Old 10-30-2011, 06:46 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I asked my dad, he said he had the same problem on the F-150 before we sold it....i would check those out....
Old 10-30-2011, 07:33 PM
vfelix702's Avatar
vfelix702
vfelix702 is offline
I would say rear main
Old 10-31-2011, 12:22 AM
Aune163rd's Avatar
Aune163rd
sorry he said flywheel bolts....
Old 10-31-2011, 08:14 AM
snaponprofile
Ok, I think it is the flywheel bolts too considering there is no oil behind the flywheel.
Old 10-31-2011, 05:12 PM
snaponprofile
Wasn't the the bolts, there isn't much left of the rear main. I have the ZF out, I'll get it all back together and working by tuesday night I hope. If I don't freeze.
Old 10-31-2011, 05:24 PM
vfelix702's Avatar
vfelix702
Rear main it is eh???? Take some pics!!!!
Old 10-31-2011, 09:59 PM
snaponprofile
I will, gonna replace it tomorrow.
Old 11-01-2011, 05:10 PM
snaponprofile
Got her all together, I hope this does not leak!! I will cry if it does, lol.
Any idea on how long I should let it sit before running it?
Old 11-01-2011, 05:32 PM
Aune163rd's Avatar
Aune163rd
A few hours, run it, get it to temp, shut her down.....
Old 11-01-2011, 07:04 PM
snaponprofile
I figure I'll wait for the RTV to set up a little more, I'll start it tomorrow.
Old 11-01-2011, 07:19 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
i think rtv is 24hr cure time.
Old 11-03-2011, 04:32 PM
vfelix702's Avatar
vfelix702
How bout some pics snap?? LoL
Old 11-03-2011, 06:17 PM
snaponprofile
I got it together and drove it alot wednesday and it ran with no drips. I'm still unsure though because oil started dripping out the starter drain drain hole but not out of the clutch cover? I'm not sure if it was from when it was first leaking but I'll see what the real deal is in a couple weeks.
Sorry no pics, there are alot of pics on this thread though.
How big of a job is a rear main on these? - Oilburners.net
Old 11-03-2011, 10:23 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
What kind of seal did you use?
Quick Reply: Oil leak!!
