You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The Ecoboost has about 11K on it now. The last 1,000 miles or so I'm hearing new noise associated with turbo. It's a GRRR sound for lack of a better word. Happens at each shift or when you back out of the throttle. Assuming it's some type of pressure relief valve for the turbos. What concerns me is why did this noise just start happening. Any thoughts? Thanks in advance!
Alan
Update:
Spoke to the service manager, he said this is not the first time he has heard of this. Corporate Ford claims this is normal after the turbo's get broke in. They are still going to take a look at it to make sure nothing else seems suspect.
I've also had this start happening. Which is why I signed up, I was wanting to see how many others are noticing this.
It's the bypass valve "trumpeting". I've had my share of turbo cars and typically the bypass/Blow off valve is one of the first mods you get out of the way, stock bpv are always junk. We're absolutely loosing power because of this.
The valve spring has softened up and now doesn't fully seat closed when needed. That valve should not be open while under boost. It should all be directed to the intake. Instead it's short cycling in the intake track.
I'm bringing my truck in for an oil change soon and I'm going to have them replace it. I've noticed that I lost .20MPG since it's started this. I was always stuck at 18.1-17.9 until this started. Now I'm sitting at 16.9-17.5. Junk.
I love my truck to death but it's horribly annoying to listen to when I know I'm being robbed power and wasting gas.
*edit, I'd like to also add that this is on a 11 F150 Crew cab.
Let us know how your visit goes. Mine seems to have been happening more since it's cold out.
My ecoboost has made the noise since new. I put a cold air intake on and that makes the noise alot more noticable. Dealer put computer on to monitor the truck and found out the turbo drops out off and on and that is when the noise is heard. The best mileage I can get is 14 m.p.g. To me it sounds like I am going over a rough road or the rumble bars on some highways. The vibration can easily be felt or heard especially on the passenger side.
Response to: My ecoboost has made the noise since new. I put a cold air intake on and that makes the noise alot more noticable. Dealer put computer on to monitor the truck and found out the turbo drops out off and on and that is when the noise is heard. The best mileage I can get is 14 m.p.g. To me it sounds like I am going over a rough road or the rumble bars on some highways. The vibration can easily be felt or heard especially on the passenger side.
I had this same rumble strip noise that could be felt especially on the passenger side. Tech replaced a vacuum relay part that keeps the front hub from engaging on the passenger side...he explained that vacuum keeps them from engaging until the vehicle is switched into 4 wheel drive. He said it was slightly leaking which allowed the fingers to just start to engage and this partial engagement caused the rumble noise and vibration. He replaced the part and it took care of it. If you want I can dig up the invoice out in the shop and see exactly what the part was.
Any help would be appreciated. I would like to show the invoice to my dealer. They are still looking at the turbo's.
I could scan and email them to you if you provide an email address. On the initial visit the tech wrote CUSTOMER STATES THERE IS A NOISE WHEN PULLING A TRAILER LIKE YOU ARE GOING OVER RUMBLE STRIPS WHEN IN SIX GEAR AND THEN WHEN IN FIFTH GEAR COULD FEEL LIKE A RUMBLE ON THE FLOOR. FOUND THE CHECK VALVE AT VACUUM SOLENOID. ORDERED VALVE. .40 79. Not sure what the numbers mean...I also think he forgot the word leak. On the visit when he fixed it he wrote CUSTOMER STATES THERE IS A NOISE COMING FROM THE FRONT OF THE VEHICLE. PARTS ARE HERE ON PRIOR VISIT. WE DIAG FOUND THE CHECK VALVE DROPPING VACUUM. REPLACED VACUUM SOLENOID. RETEST OK. Initially it occurred when under load like pulling a trailer. It also would change when forcing a down shift to 5th. The tech said that makes sense because the rpm's would change and change the available vacuum. Long story short he nailed the diagnosis and it now works fine.
Update: Last week when I pulled a trailer no noise. This morning I pulled my enclosed trailer and the rumble-strip noise and vibration are back. It is intermitent. Back to the dealer.
