View Poll Results: Did you break a plug and did you use kroil
No break, I used kroil
25.00%
No break, I did not use kroil
30.00%
Break, I used kroil
15.00%
Break, I did not use kroil
30.00%
Voters: 20. You may not vote on this poll
Did you break a plug? Use Kroil?
Old 10-30-2011, 02:58 PM
Ted928's Avatar
Ted928
Ted928 is offline
If you changed your plugs, did you break any? Did you use kroil? I think the people who used kroil (as opposed to some other penetrating oil) have been very successful so let's see what the poll says.
No break, did use kroil
No breaK, did not use kroil
Break, did use kroil
Break, did not use kroil
Old 11-01-2011, 08:49 PM
Ted928's Avatar
Ted928
Ted928 is offline
79 viewers so far but no one is polling. Why???
Old 11-02-2011, 06:31 AM
elrodalonzo's Avatar
elrodalonzo
elrodalonzo is offline
There are 10 million posts on this topic, I think people are polled out!
Old 11-03-2011, 12:23 PM
gmcgilli66's Avatar
gmcgilli66
gmcgilli66 is offline
Dealership changed out plugs. Broke 4!!!!
Old 06-18-2016, 03:37 PM
ITDave's Avatar
ITDave
ITDave is offline
I would like to know the answer to this one. Want to change the plugs today, but cannot locate this AeroKroil by Kano... :/
Old 06-20-2016, 02:08 PM
milliesdad's Avatar
milliesdad
milliesdad is offline
I cracked the plugs about a 1/4 turn, then sprayed Sea Foam in and let it word for about an hour. Got 3 plugs out whole.
Old 06-20-2016, 02:46 PM
bleoh's Avatar
bleoh
bleoh is offline
I ran Techron through my fuel system for several tanks of gas getting ready to do the plugs. Cracked plugs a 1/4 turn and used PB blaster on a warm engine, let soak 10 minutes or so. Then used a 3/8 electric impact gun on all but the two rear plugs (no room for my impact). On those I just took my time loosening the plug a little at a time until it felt tight or "funny" at all. Then I would jump to another plug and work on that and come back to the rear plug after the PB soaked in more. All 8 of my original plugs came out in one piece from my 2004 with 96K miles on it.
Old 06-22-2016, 09:24 PM
thousand_mile_stare's Avatar
thousand_mile_stare
thousand_mile_stare is offline
I broke none. Followed the Ford TSB. Used Supertech carb cleaner available at Walmart.
Old 06-30-2016, 02:01 PM
jhayden's Avatar
jhayden
jhayden is offline
I ran 2 tanks w/ techron, warmed engine , 1/4 turn plugs loose drivers side. sprayed w/ pblaster, whole side came out in 1 piece. rewarmed engine, did the same for the other side, none broke. Engine had 105k on it, at the time. I have found magnetic plug socket works best for me, in this application.
Old 07-01-2016, 12:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
I've changed the plugs in my '07 F150 5.4 3V twice, 95,000 miles and 191,000 miles. Both times in the three fill-ups before the plug change I added a can of Seafoam, then with a cold engine I cracked the plugs about an 1/8 turn and poured Kroil into the spark plug well. Waited two hours and then, carefully, removed the plugs. If any showed resistance, I would screw it back in then screw it in and out, each time screw it out a little further until it eased up. Once they were all out, I reinstalled the PCM to spin the engine over to clear out the Kroil that dropped into the cylinder.
I used nickle based Never-seize on the new plugs.
So far, sixteen plugs and none have broken.
DWinTX
2004 - 2008 F150
20
06-02-2020 08:07 AM
5.43v
2004 - 2008 F150
08-13-2018 08:50 PM
rang5.0
2004 - 2008 F150
04-15-2012 08:59 PM
pjw73nh
17
09-02-2011 05:17 AM
expy37at
1997-2006 Expedition & Navigator
05-12-2010 06:55 PM
Quick Reply: Did you break a plug? Use Kroil?
