i found a bronco rear bumper, only dentless one at a junkyard. i read on google that the brackets are different. can i use the 87 bronco bumper and attached it to my stock 95 f150 brackets?
oh ok. thanks. so the short ones right behind the license plate i believe that point straight dont fit. the support brackets do fit. i still have my old damaged bumper so i'll swap the main brackets
i got the bumper from a junkyard yesterday. i thought the supporting brackets were the same. my f150 supporting brackets dont fit the bronco bumper maybe its just bent. i'll find out.
its hard as hel to get those bolts off after the bumpers off the truck.
IIRC, the bumper brackets are only different on the different body styles.
I put a bko front&rear bumper on my truck a couple years ago to replace damaged bumpers. My 150's a 94 and the bko was a 93, didn't have to swap brackets if I remember correctly.
Needless to say, my bumpers are almost as bad now
