shift flare when cold - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 10-30-2011, 10:27 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
I have a 2008 EB Expedition that has 2-3 shift flare when cold. As the transmission warms up it seems to go away, or at least not as noticable. It had the same problem last winter just not as bad as it is now. Had a reflash last year, and the transmission filter/fluid changed hoping it would correct the problem. The reflash helped improve a downshift thump it had but not the 2-3 shift flare. Has anyone else had the 2-3 shift flare and if so what was done to correct it? I plan on taking the vehicle to the dealer but would like to know if it is a common problem and what to expect for a fix.
Tags
2005, 2008, 2010, 60, cold, escape, flair, flare, ford, shift, taurus, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
