Brotherhood of the travelling hub zerk
#423
I appreciate everyone's contribution to this subject and have learned a great deal from them. I was experiencing some significant road noise and believed it to be tires at first. I did realize that if I took a left turn the noise disappeared and if I took a right turn the noise slightly increased. Unfortunately the day before I was to leave on a road trip I learned the passenger side bearing had failed by jacking up the front end and shaking the tires. I replaced the bearing assembly with one of the cheap ones ($115). It appeared to be a quality piece, however. I figured the other bearing is not far behind so I wanted to grease it as others have done here. So, I bought a special fitting. It is about 1/4" diameter with a rubber conical tip and a zerk on the other end. It worked OK but the rubber tip came off in the hole. I was able to get it out with a pair of needle nosed pliers. For a moment I was wondering, however. I suggest getting the right fitting from someone here if you have time. I also greased the new hub which took a lot of grease. It told me that there was not much grease in it. I used a Mobil synthetic grease. I think of tapered roller bearings to be about indestructible as long as they are lubricated. I am thinking that as long as these bearings are greased once in a while they will last indefinitely, but maybe I am wrong. I am curious as to how long my new cheap bearing and other well used bearing will last with the quality grease. My X runs so quiet now I can't believe it.
While on my trip darned if I didn't see someone at the campground where I was staying changing one of his front bearings. I gathered that this was not his first. I told him about greasing them but his truck does not have ABS so there was no provision. I suggested he buy his next bearing with the ABS sensor if it is otherwise the same so he can service them.
Again, thanks for everyone's contribution here!
Nelson
Nelson
#424
Let me dig up my original drawing for you.
Here it is:
https://www.ford-trucks.com/forums/6...ml#post5021552
Pop
Here it is:
Pop
Thanks, Pop. I'll get on this after we get home from vacation... And the lawn is mowed, fence painted, oil changed, bills paid...
Curt
#426
#429
It is possible, I do sort of remember an Ithaca but can't be sure. I have sent out all the requests I got up till about 4-6 days ago. I did receive two more letters since I sent the last bunch but those just came in within the last few days or so.
#431
Hi there,
Just looking through the forum and wanted to see what the process is for borrowing your grease fitting?
Appreciate your help,
Kevin
Kevin
#432
#433
#434
