help
help
i just brought a 1997 power stoke 4 dr truck with the lxt package 4x4 auto i have a couple of questions frist is if i have brake turn signals working but no tail light what do i check for. second question is the radio wiring harness was cut badly where do i find a diagram to find out which wires are what. thrid question is i have a small fuel leak from top running down the right bank to the ground i need some pointers and help please
on your running lights make sure your fuses are good in the cab, does the insturment cluster light up? how about headlights?
radio here are two schematics first is with the premium sound option
then without it
fuel leak could be a number of things the fuel pump is right there along with multiple lines and o-rings best thing to do is clean it up and let it run trying to look for the leak.
then without it
oldschool84f150
10-13-2009 12:07 AM
jlancaster
08-07-2004 08:52 PM
