240 to 302 swap
240 to 302 swap
I have a '66 f100 with an inline 240 that is locked up. Looking at swapping in a 302 and a tranny. I want a 4 speed to go with it. I've been doing a ton of research but there is so much info that my head is spinning! I need recommendations: which year should I be hunting for and which tranny would be a good match with stock 3.73 gears? Don't need or want all the modern electronics! Thanks in advance!
on
Look for a '87-96 5.0/5-spd to swap in, after you strip the motor bare you can mount a carb and intake no problem, stab a DS2 or mechanical distributor and bolt it in.. with the right engine mounts n stuff of course. Of those the '94-96 motors will be the most potent but if you're really lucky you will find an Explorer 5.0.
I wouldn't worry about getting an OD transmission too much. After all how much are you really going to drive it ? With those 3.73's and your typical pickup truck tire diameters, you really don't need an OD top gear to keep the revs down. What transmission was behind the 240 ? I don't recall if the 240 bell bolts up to a small block or not. I ran a carbed Explorer 5.0 in an 89 Ranger with a Toploader 4 speed and a 3.73 rear with 28" tires. It was a blast to drive around town and got decent fuel mileage out on the highway cruising at 70-75 (16 mpg)
vpracer06
11-28-2007 07:09 AM
