Dana 60 front axle swap
77 lowboy means you have leaf springs up front, I'm guessing?
Its not that much fabrication, just outboarded LS mounts... You can go to a junkyard and prolly find yourself some factory mounts that will fit if thats your bent, I think ruff stuff sells some that will work, and I've seen them made out of box tube. If you can get the newer 60 cheap enough to warranty the work, its not like is that big of a deal.
It sounds like a lot of trouble to relocate the front spring mounts and make/find new shackles, but in the grand scheme of things its pretty simple. Take a look at what IFS chevy guys do to get a solid axle up front. Though I'd probably just stick with the 44, if you have your heart set on a 60 and come across a later model unit for reasonable I say go for it. I just picked up a low mile 93 ball joint axle in the boneyard of all places, and for $300 to boot. I think I'd fall over if I came across a 78/79 unit in the yard, let alone for that kind of money.
80% of chevy SAS are done on the inside of the frame, here is my kit. It's to be used for 32" spring pads. There is only one company that makes a 36.5 kit (If I remember correctly), and then the rest are 32" leafs, coil sprung, or home made.
we are starting to get off topic. But basically, I'd wheel that 44. If you really want a 60 and cant find a ford one, consider a chevy or dodge and run the dodge divorced transfer case to replace yours.
How do you like Sky's kit? There are a bunch of kits out there for the 36 inch axles now. I have a 79 and the aforementioned 93, and have been looking at putting one or the other into my obs silvy. The kits for the 36.5 are still inboard the frame at the shackles, but just a bit off the outside front frame rail. Fabworx makes the best looking/strongest kit for the 36 inch axle as far as I can tell, and will probably be the route I chose.
we are starting to get off topic. But basically, I'd wheel that 44. If you really want a 60 and cant find a ford one, consider a chevy or dodge and run the dodge divorced transfer case to replace yours.[/quote]
We might be getting a little off topic but seeing that i started the thread i must say that i'm getting an education from all of you so Thank You all even if it went off road LOL for a spell. This is what makes this such a great forum!
Thanks Again
Tony
AKA Stinky
Thanks Again
Tony
AKA Stinky
#28
for the money you would spend on a 60 you can go full chromoly on the 44 and have the same strength as a stock 60. And its a good bit lighter. If youre not gonna beat on it thats what I'd do. Or just spend a couple hundred on decent aftermarket shafts and replace stuff as you break it. Can't go wrong by not fixing what isn't broke.
#29
#30
